Makita 3612c - Router Forums
post #1 of 18 (permalink) Old 11-13-2008, 03:58 AM Thread Starter
Default Makita 3612c
I have just splurged out on a Makita 3612C (boy, is it heavy)
can anyone suggest a template guide set for this router...
jw2170 is offline
post #2 of 18 (permalink) Old 11-13-2008, 08:54 AM
I thought you already had a 3612C James. Timbecon sell an Imperial brass set which is listed for Makita and similar routers. I have a set and have sleeved some of them to metric. This very day I used a 16mm one on my current project, photo-shoot in a week or so, It has to go for laser engraving. Makita of course supply guides including, if they still have stock, the elusive 40mm.
Harry
Electron is offline
post #3 of 18 (permalink) Old 11-13-2008, 06:48 PM
Default Template Guides
Makita have their own set of Guides suitable for that router. I would not recommend looking for a set of guides (other than Makita0 as you will find that they are usually in imperial and most sets do not have the 40mm included. Makita do have available 40mm
Tom
template tom is offline
post #4 of 18 (permalink) Old 11-13-2008, 08:30 PM Thread Starter
thanks electron, & template tom.
I note, Tom, that you were involved in a similar discussion on the Aussie wood work forum in 2006.....
Where would you suggest I source the Makita guides?
jw2170 is offline
post #5 of 18 (permalink) Old 11-15-2008, 04:39 AM
James I would make a quick call to Makita in Sydney where they will direct you to the nearest store where they are available.
Tom
post #6 of 18 (permalink) Old 11-15-2008, 06:40 AM Thread Starter
Thanks Tom,
I was able to locate the part number on the web and will call to the local Makita outlet next week-end, (had to go sailing today --
Makita also have an adapter that allows the use of the Router Workshop guides.
Has anyone used that?
jw2170 is offline
post #7 of 18 (permalink) Old 11-15-2008, 09:08 AM
"Timbecon sell an Imperial brass set which is listed for Makita"
Didn't you read my post James? I have this set and they are fine with the 3612C, the only problem is that they are Imperial, but let's face it, you can still buy imperial cutters here, not that it's necessary. The only problem that I find with Imperial is calculating off-sets.
Harry
Electron is offline
post #8 of 18 (permalink) Old 11-15-2008, 09:21 AM
Hi James
I don't have the Makita but I wanted to do the same as you, I wanted to use the bigger brass guides so I reworked a base plate to take them on I also made one or two new router base plates to take on the OP type guides
I do like to use the 1 1/2 " guide alot of the time,below you will see a Porter Cable router with the new reworked base...it's no big deal to rework it.
Or make a new router base plate
http://www.leevalley.com/wood/page.a...000,51208&ap=1
Thanks Tom,
post #9 of 18 (permalink) Old 11-15-2008, 04:17 PM
Hamlin's Avatar
First Name: Ken
Hi James,
You should have some paper work with the new purchase that has list of local retailers for extras.
I personally use the OP plates with OP guides.
Ken
"A VETERAN"
Hamlin is offline
post #10 of 18 (permalink) Old 11-16-2008, 04:25 AM Thread Starter
Hi Electron (Harry????)
I did not mean to make it seem that I was ignoring you...
In fact I already have a similar setup that I purchased from CarbeTec some months ago. (their universal router plate and guide bushing set). I originally bought this for the Ryobi and it is a perfect fit on the Makita. Installed it this afternoon.
I will still be looking at the Makita 40mm bushing in the future.
I note that the circle jig I bought from Lee valley some time ago also fits the makita. (bonus).
I did not previously have a Makita although I did make some inquiries about this router in September.
At that time I thought it was too dear. I had some holiday money left over and one of the tool chains (United Tools) had it in their catalouge for $A586. I got it for $A575 as I walked into the wrong store>long story...
I note that the soft start is not as good as the ryobi (it kicks on start up) and , boy, does it kick on switch off (must be the brake).
Anyway, the Ryobi is on the back shelf and the Triton is still in the table.
jw2170 is offline
Makita 3612C Manual & Parts links Hamlin Makita 5 07-21-2010 03:43 AM
Makita 3612C TWheels General Routing 8 11-23-2008 07:58 PM
makita 3612C table mounted locoboy Table-mounted Routing 11 10-17-2008 09:57 AM
makita 3612 / 3612C jw2170 General Routing 6 09-01-2008 06:37 AM
template guide and 1/2" collet pab Portable Routing 4 08-11-2006 07:59 AM
