Help with router inlay kit - Router Forums
 1Likes
  • 1 Post By Semipro
post #1 of 5 (permalink) Old 05-08-2017, 12:24 PM Thread Starter
First Name: Teddy
Question Help with router inlay kit
My Task
Inlay a 3" x 5" oval into a workpiece
My Resources
DeWALT DW618 Plunge Router
Whiteside 9500 Inlay Kit (1 3/8" insert, 5/16" OD Barrel, 9/16" OD collar, 1/8" Down Cut Spiral bit)
1/4" X 1' x 1' Hardboard Panels
maple stock for the oval
11" x 9" workpiece
3" X 5" oval from craft store
I'll need to cut both the recess and the actual oval that will go into the workpiece. It's my understanding that the hole in the hardboard template will need to be larger than the oval itself to accommodate the bushing and bit. Since the craft store oval is the same size as the maple oval that I want, do I just need to attach the 9/16" collar and cut the hardboard using the craft oval as a guide? Then use the hardboard template with the 9/16" collar to cut the maple oval. Then remove the collar and just use the 5/16" barrel when cutting the recess in the workpiece? Or will I need to use a different size insert for making the template.
Celebane is offline
post #2 of 5 (permalink) Old 05-08-2017, 12:38 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the router forum Teddy
Go here see if this will help you ( routerworkshop)
Router Workshop: Making An Inlay Template
I use this inlay kit
Celebane likes this.
Thank You John
Semipro is online now
post #3 of 5 (permalink) Old 05-08-2017, 12:59 PM Thread Starter
First Name: Teddy
Thanks... that's the same inlay kit I have. My main concern is when I'm actually doing the cutout for the template do I simply do it with the collar on or is there a different sized bushing I'll need to use.
Celebane is offline
post #4 of 5 (permalink) Old 05-08-2017, 02:28 PM
Semipro's Avatar
First Name: John_*
Remove the collar to make your template install the collar to cut you project material
I would test your template before cutting you good material on a scrape piece
Thank You John
post #5 of 5 (permalink) Old 05-08-2017, 02:40 PM Thread Starter
First Name: Teddy
Thanks very much. I've gotten really good at making sawdust and firewood.
Celebane is offline
Bosch Router Kit Question coxhaus General Routing 16 02-11-2015 07:03 AM
Making an Inlay and Inset Drawer Pull learnexperience General Routing 0 10-31-2011 06:48 AM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
another kit or a dedicated table router? rprice54 General Routing 11 08-06-2009 07:51 AM
