Template Guide Bushing Interference - Router Forums
 5Likes
post #1 of 12 (permalink) Old 08-16-2017, 09:41 AM Thread Starter
First Name: Tanner
Default Template Guide Bushing Interference
This may be a simple answer, but wanted to check with the resident experts around here.
I am creating a router table and using the Jessem MDF Template to create the opening for the router lift. The instructions call for a 3/4" O.D. template guide bushing with a 1/2" straight cut router bit.
As you'll see in the attached pictures, I am not getting enough depth out of the cut and the lock nut is actually coming in contact with the brass template guide which as you can guess, is causing the bushing to loosen.
My question is, should I look at getting a longer bit or is there an extension that can be used?
Thanks in advance.
thawey is offline
post #2 of 12 (permalink) Old 08-16-2017, 10:27 AM
Tanner, you have a couple of options on this. The easiest route is to buy a longer bit. I always recommend to new members that they buy guide bushings with all 1/4" height bushings for exactly this reason. You can cut yours down to a hair under 1/4" height. An extension will not help in this situation as it would hit the bushing too.
post #3 of 12 (permalink) Old 08-16-2017, 10:31 AM
hawkeye10's Avatar
First Name: Don
You either need a longer bit or a shorter shoulder on your template guide bushing. As for the nut on the guide bushing coming loose I don't understand what is going on but it shouldn't come loose.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 12 (permalink) Old 08-16-2017, 10:33 AM Thread Starter
First Name: Tanner
Thanks Mike, that was my initial thought - get a longer bit.
You also reference the height of the bushing, this I was not aware of as my local store didn't have variable heights for the bushings. I'll start with the bit first and then look in to adjusting the bushing height as needed.
All the best.
thawey is offline
post #5 of 12 (permalink) Old 08-16-2017, 10:36 AM Thread Starter
First Name: Tanner
As the router was spinning, it came in contact with the guide bushing which loosened it up.
thawey is offline
post #6 of 12 (permalink) Old 08-16-2017, 11:09 AM
I think I had to buy the 1/4 bushing set from Woodcraft. I had to do some searching to find them. As to a bit hitting the bushing. That is a function of centering the base on the router, which requires a centering cone. The cone has a shaft, which you place in the collet, then fit the base down on the cone until it meets the router's bottom. Put the bolts in and it's centered. If the removable base comes loose, it can shift and the bit will hit the bushing.
Unless something else is going on, re-centering the base is the first order of business.
post #7 of 12 (permalink) Old 08-16-2017, 11:27 AM
If you shorten the guide bushing you can use thinner material for a template which will give you effectively more reach. 1/4" material is usually good enough for templates so the guide bush only needs to be 7/32" long. I've never figured out yet why some of them are so long becuase even if you use a thicker template you still don't need a long guide bush.
One other strategy you can use is to rout as much as you can with the setup you have. This will leave your work to a finished shape but only to a partial depth. You can then thake the work and flip it upside down on the table and use a flush trim bit instead of a guide bushing. The flush trim bit will follow what has already been routed.
Danman1957 likes this.
post #8 of 12 (permalink) Old 08-16-2017, 12:15 PM Thread Starter
First Name: Tanner
It's not the bit that's hitting the bushing, it's the lock nut hitting the bushing (see first pic). I do have the centering cone and have completed that as part of the initial router set up.
I will look in to the Woodcraft set if a longer bit doesn't solve the initial problem.
I agree, the guide bushing is far too long, but I don't have the ability to make a thinner template as it is a pre-made one provided by Jessem and it is quite thick. So, with the thick template and deep throat of the guide bushing, I am certain I need a longer bit.
Good tip, I will definitely add this to the list of items to try.
Thank you all for your insights, I can already see this is a great community with a lot of support.
thawey is offline
post #9 of 12 (permalink) Old 08-16-2017, 12:48 PM
kp91's Avatar
First Name: Doug
The belt sander does a great job of shortening brass template guides
Danman1957 and DesertRatTom like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #10 of 12 (permalink) Old 08-16-2017, 11:52 PM Thread Starter
First Name: Tanner
Problem solved with a longer bit - thank you for all the recommendations.
TenGees likes this.
thawey is offline
Advice on Cable Grommet Techniques plunger Starting Off 13 10-03-2015 01:03 AM
template routing bushing jg2259 Guide Bushings and Templates 12 03-18-2014 07:55 AM
Inlay work with template guides : a guide matt1710 Guide Bushings and Templates 11 01-22-2012 04:36 PM
PC style guide bushing as inlay allister Guide Bushings and Templates 2 03-30-2009 06:34 PM
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
