Rockler Signmaker Guide Bushings - Router Forums
post #1 of 2 (permalink) Old 09-16-2017, 06:06 PM Thread Starter
First Name: Ken
Default Rockler Signmaker Guide Bushings
The Rockler Interlock Signmaker template description says "The Interlock Signmaker's Kits require either a 3/8'' (#33967, sold separately) or 5/8'' (#30933, sold separately) guide bushing" and (3/8" for 2-1/4" kits & 5/8" for the 4" Kits ).
The #33967 bushing for the 2-1/4" kit has 3/8" ID, 1/2" OD. The #30933 bushing for the 4" kit has 5/8" ID, 3/4" OD.
I have a Bosch 1617 router and a Bosch PR20 Colt router - both with respective plunge bases and the Bosch RA1128 quick-release template guide bushings.
My question: Is the Bosch guide bushing's OD dimension the key characteristic when determining compatibility with the Rockler sign templates?
I would think that the ID is only relevant to making sure that the router bit does not contact the guide bushing. I have the centering bit to make sure that the bushing is centered.
Do you think the Bosch guide bushings will work as well as the brass Rockler guide bushings?
KennK is offline
post #2 of 2 (permalink) Old 09-16-2017, 06:48 PM
kp91's Avatar
First Name: Doug
Ken,
OD is all that is important.
1 John 1:9
Fredericksburg, VA
kp91 is online now
Metric bits and guide bushings Mike The Voting Booth 29 05-09-2012 09:08 AM
matching Bosch router to PD guide bushings. drtimdc Guide Bushings and Templates 5 01-03-2010 06:18 AM
Help! Rockler Std. Guide Bushings? Richard44 General Routing 3 06-20-2009 01:12 PM
routers levon Table-mounted Routing 18 10-03-2008 09:11 PM
Rockler Router Edge Guide reds_21 Jigs and Fixtures 1 02-06-2005 10:25 PM
