Elu dovetailing jig - bushing diameter please? - Page 3 - Router Forums
 2Likes
post #21 of 24 (permalink) Old 12-26-2017, 01:49 PM Thread Starter
JCJCJC's Avatar
Country: Ireland
Hi Ray, thanks for your reply. That screw is not the root of the problem - the router sits flat, the head of the screw doesn't stick out past the baseplate, I checked that with a straightedge before I used the setup you see.
Regards JC
JCJCJC is offline
post #22 of 24 (permalink) Old 12-27-2017, 11:22 AM Thread Starter
JCJCJC's Avatar
Country: Ireland
Update - I've made and attached the spacer blocks to avoid the damaged slots. I'm afraid I perhaps should have made them wider - time will tell as soon as the new cutter arrives.
JC
JCJCJC is offline
post #23 of 24 (permalink) Old 12-27-2017, 11:24 AM Thread Starter
JCJCJC's Avatar
Country: Ireland
Pic of the spacer blocks.
JCJCJC is offline
post #24 of 24 (permalink) Old 01-01-2018, 02:29 AM
Country: South Africa
First Name: Biagio
Hi Ray, may 2018 treat your template better than 2017.
I notice a smudge of red paint on the collar of your bushing in the photo. From what I remember, there was little or no wiggle room between the template fingers and the collar. Also, the original was not painted. Perhaps the paint you applied tightened the gap too much?
Try scraping the sides of the fingers, and check that the guide bushing (mounted on the router, in case there is some slight deviation from perpendicular between the bushing plate and the collar) slides easily between all the fingers. Also, check that the template itself is not distorted, either from front to back, or across the thickness - a small bump could cause the fingers to pinch.
Finally, do what I did at the beginning: make yourself a prominent sign that says: "BEFORE all else fails, switch off the router". I need to resurrect it soon, as I want to make some half-blind dovetails, and know that I have lost the habit- too much reliance on a table-mounted router.
A thought: depending on the wood, you may get some tear-out on the right side of each dovetail. It helps to start each cut with a couple of small "bump" cuts, before proceeding along the length of the fingers - removes some of the fibres which might tear out.
Biagio is offline
Sears Mortise and Tenon jig Bushing Size Char General Routing 13 01-08-2017 12:05 AM
Small router for dovetailing jig oilcan21 Jigs and Fixtures 6 01-20-2011 06:42 AM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
short dado's krimson_cardnal Jigs and Fixtures 16 06-13-2006 12:28 PM
