Bushing disaster - Router Forums
 3Likes
post #1 of 13 (permalink) Old 12-12-2017, 04:29 PM Thread Starter
First Name: Dale
Default Bushing disaster
The bushing did not fit, surface A was 1/32 higher than surface B. I attempted
to lower it by using a moto-tool. All I did was cut one half down 1/64, the other
is all gouged up. The hole still is perfectly round.
My solution was to buy a new plate, but I would still have the same overly high
bushing. So, I just sent for a 1-3/8 Forstner bit, and I will Ďattemptí to bore the
good edge down and into the gouged edge.
The only drawback I can foresee, if I am successful, is that the bushing will be
recessed below the bottom of the disc by about 1/16Ē.
That means my 7 bushings all have a 1/8Ē collar!
Please donít comment about the 2 mystery holes.
Dale
DaleFiorillo is offline
post #2 of 13 (permalink) Old 12-12-2017, 04:32 PM Thread Starter
First Name: Dale
Surface A is raised higher for illustration purposes.
post #3 of 13 (permalink) Old 12-12-2017, 05:40 PM
Dale it would matter if the bushing sits high of the base plate but I can't see a problem if it is sitting a bit recessed into the plate.
post #4 of 13 (permalink) Old 12-12-2017, 07:20 PM
CharleyL's Avatar
First Name: Charley
When trying to use a Forstner bit to counter bore an existing hole like you seem to be planning, the only way that I found that works well is to use the larger Forstner bit to first drill a hole in a piece of thick (3/4" or thicker) wood. Then position and clamp this piece of wood to your work so that the hole in the wood is aligned with the smaller hole in your work. Then use the Forstner bit through the hole in this piece of wood to drill the counter bore. The wood piece will serve to guide the Forstner bit where there is no center point to guide it. I would not try this without using a drill press to drill the larger counter bore because the Forstner bit might bind if you try this with a hand drill and ruin the work. Doing it this way along with careful control of the bit depth should be successful in creating the counter bore that you want.
Another way would be to use a small bottom bearing rabbeting bit to make the counter bore, if you can find one this small.
Charley
Gaffboat likes this.
Central North Carolina
CharleyL is offline
post #5 of 13 (permalink) Old 12-12-2017, 07:25 PM Thread Starter
First Name: Dale
Agreed. Instead of power drilling, I’m thinking of turning the bit by hand, very slow and carefully.
post #6 of 13 (permalink) Old 12-12-2017, 08:12 PM
vchiarelli's Avatar
First Name: Vince
Dale: Couple of questions for you - is this an aftermarket plate and what was it predrilled? What router is it for?
I had a set of bushings that wouldn't fit the base plate of my PC690. I found that the hole in the base plate had tiny tabs that prevented the bushing from sitting flush. An exacto knife to remove those tabs fixed it for me.
vchiarelli is offline
post #7 of 13 (permalink) Old 12-12-2017, 09:12 PM Thread Starter
First Name: Dale
Hi Vince, the router is a Ryobi 180PL, which really works nice. The subplate is from Eagle, and it is not predrilled at all.
I bored the mounting bolt recess on the wrong side. I had lots of room to redo a new set of holes, and without
any overdrilling for adjustability the centering was perfect!
My bushings are the cheapo HF, and I cut all the collars to 1/4”. I wonder if all these bushing sets are intended to
be used with special templates?
post #8 of 13 (permalink) Old 12-13-2017, 12:11 AM
Terry Q's Avatar
Before I went any further Iíd see if bushings from a different source might fit flush.
If you are wondering why Porter Cable type bushings come in different lengths, I think itís because they were originally developed for their Omnijig dovetailing fixture.
Terry Q is offline
post #9 of 13 (permalink) Old 12-13-2017, 08:55 AM
CharleyL's Avatar
First Name: Charley
Dale,
Turning that bit by hand is going to take you forever to cut the hole to the depth that you need. Just carefully set the depth stop on your drill press and drill a test hole in scrap the same thickness as your work piece to be sure that you have the stop set correctly. Use the wood block with the hole to guide the bit, and your bushing recess will turn out perfect. I have done this several times without a problem.
Charley
CharleyL is offline
post #10 of 13 (permalink) Old 12-13-2017, 09:20 AM
Honored Member
harrysin's Avatar
First Name: Harry
In this project I show how I routed the hole and rebate using a circle routing jig.
Harry
harrysin is offline
Guide bushing identification Mike Guide Bushings and Templates 42 09-22-2013 09:25 PM
Router Bushing bobj3 Guide Bushings and Templates 5 05-06-2013 07:22 PM
Guide bushing fabrication johnpaulh Guide Bushings and Templates 10 01-30-2012 07:32 AM
Routing a cavity with a close fitting lid? digitalrust Guide Bushings and Templates 13 07-05-2011 11:33 AM
