Why use bushings instead of bearings - Router Forums
 10Likes
  • 1 Post By Cherryville Chuck
  • 3 Post By kp91
  • 5 Post By harrysin
  • 1 Post By JFPNCM
post #1 of 10 (permalink) Old 12-15-2017, 04:54 PM Thread Starter
First Name: Randy
Default Why use bushings instead of bearings
If you were cutting a pattern why use those insert bushings instead of a bit with a top mount bearing?
Are bushings used mainly to make it easier to control the depth of the cut?
.......just askin' when to use one method instead of the other.
ranman is offline
post #2 of 10 (permalink) Old 12-15-2017, 05:12 PM
You can use them with bits that don't have and/or can't accept bearings, like a spiral bit for example. If you are dovetailing with a jig then you need them for that too.
Roy Drake likes this.
post #3 of 10 (permalink) Old 12-15-2017, 05:25 PM
kp91's Avatar
First Name: Doug
If you are using a fixture or pattern, it is much easier to damage it with a bearing guided bit than when using a template guide bushing.
Not all bits have bearings, like core box, v groove, etc. and templates are an easy way to guide them
You can sneak up on a cut with templates, do a rougher pass with a larger diameter, then shift to a smaller for the finish pass
fire65, TenGees and Roy Drake like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 10 (permalink) Old 12-15-2017, 11:07 PM Thread Starter
First Name: Randy
Thanks guys. That helps. I obviously don't use a router much......... not yet anyway.
ranman is offline
post #5 of 10 (permalink) Old 12-16-2017, 01:08 AM
Honored Member
harrysin's Avatar
First Name: Harry
All the above answers are correct but there are other things that can be achieved , for example, this clock. The groove in the template was routed 1mm wider than the template guide diameter. Whilst routing, the guide was being pressed against the outside of the groove then for the final fine cut it was held against the inside of the groove giving a really good finish which only required fine sanding.
Harry
harrysin is offline
post #6 of 10 (permalink) Old 12-16-2017, 12:30 PM
JFPNCM's Avatar
First Name: Jon
Excellent points. Another lesson learned.
Starting a bowl with a guide bushing and then converting to a bearing guided bowl bit saves wear and tear on the template as well.
kp91 likes this.
Jon
JFPNCM is offline
post #7 of 10 (permalink) Old 12-16-2017, 04:55 PM
kp91's Avatar
First Name: Doug
BobJ used to laugh at me for recommending Bondo for repairing templates, but it works perfectly
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #8 of 10 (permalink) Old 12-16-2017, 05:00 PM
JFPNCM's Avatar
First Name: Jon
@kp91
Good idea to keep in mind. Thanks.
Jon
JFPNCM is offline
post #9 of 10 (permalink) Old 12-17-2017, 08:59 AM
Honored Member
harrysin's Avatar
First Name: Harry
That is true Jon but I found that the bearing leaves a mark that has to be sanded out.
Harry
harrysin is offline
post #10 of 10 (permalink) Old 12-17-2017, 09:03 AM
Honored Member
harrysin's Avatar
First Name: Harry
Bob and I were at one with this method of template repair.
Harry
harrysin is offline
Oversized guide bushings and storage Mike Guide Bushings and Templates 7 09-04-2016 12:40 PM
what size insert rings for pc guide bushings? Goblu Guide Bushings and Templates 5 03-03-2015 06:22 AM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 02:11 PM
Bushings or Bearings hdoilcan Guide Bushings and Templates 17 12-11-2011 11:08 AM
bushings vs bearings peacefrog Guide Bushings and Templates 4 11-08-2007 10:39 AM
