Rounding corners of table insert - Router Forums
 11Likes
post #1 of 18 (permalink) Old 12-23-2017, 03:04 PM Thread Starter
First Name: Randy
Default Rounding corners of table insert
I made my own aluminum mounting plate for my router which will end up in my future table top.
I cut the plate with a table saw, then cleaned up the edges with my router. OK, ...so I now have a nice pretty and square plate.
I'm curious about a couple of things.
What's the "typical" radius of a store bought insert plate's corners? Mine it totally custom, so I suppose that's not really an issue.
I have a 1/2 inch bit with a top mount bearing. If I use that bit to round the aluminum plate's corners, will I also use a 1/2 inch bit to cut the corners into the table top?
I'll need to make patterns of course to round the plate and then to cut the hole in the table top.
A half inch bit will cut a 1/4" radius in the table top.
......... so when I round the corners on the aluminum insert plate, I assume that I need to make the pattern with a 1/4 radius and that I can use the same 1/2" top mount bit to make the cut.
I'm just trying to wrap my head around making inside and outside corners that mate.
Name:	Rounding corners on the top plate.JPG
ranman is offline
post #2 of 18 (permalink) Old 12-23-2017, 03:24 PM
vchiarelli's Avatar
First Name: Vince
Randy - keep in mind that you are not routing a hole in the corners of the plate - you are rounding the corners. You will make a template that will allow you to (inside) round the hole in your table. Then you will round the corners of the plate to match that. What I'm trying to say is that you can round the corners of the plate with anything that you like because it's an outside corner.
When I recently installed a Kreg plate in a table, it called for a 3/4" radius for the inside corner of the hole I made in my table - I used a 1 1/2" forstner bit to give me that 3/4" radius.
Hope that all makes sense.
vchiarelli is offline
post #3 of 18 (permalink) Old 12-23-2017, 03:55 PM
The thing about a simple, shop made plate is that you will find it hard to use inserts, which can be changed to fit your different sized bits. Having the insert fit close to the bit size helps with above table dust collection. Suggestion on cutting the plate opening is good. As to cutting the opening for the bit, it needs to be a little bigger than the biggest bit you expect to use, which means for all smaller bits, you'll have way to large an opening. This is why most of us use commercial plates, some of which now have twist lock inserts instead of the 3-screw (where'd that darn screw go?) veriety of old. Kreg makes some nice aluminum plates for reasonable prices. And they have already rounded corners.
jj777746 likes this.
post #4 of 18 (permalink) Old 12-23-2017, 03:59 PM Thread Starter
First Name: Randy
Thanks, I know I'm rounding the corners of the plate.
If I made a rectangular template to cut the hole in the table top, a 1/2 inch router bit would make an automatic 1/4" radius in the corners.
Now if I made a template with the same 1/4" radius, any diameter flush trim bit with a top bearing would follow and cut the correct radius. I happen to have a 1/2" bit. I'm just rounding the corners a little.
I suppose I could use a larger diameter Forstner bit to make the corners in the table top, and then make a pattern for the insert plate with the same radius for rounding the corners.
Name:	Rounding corners on the top plate  w template.jpg
ranman is offline
post #5 of 18 (permalink) Old 12-23-2017, 04:05 PM Thread Starter
First Name: Randy
Way too late. My plate is part of a lift I made......... it's just about done. I went a wee bit off the deep end constructing it. One of these days I'll post some photos of it.
ranman is offline
post #6 of 18 (permalink) Old 12-23-2017, 05:26 PM
vchiarelli's Avatar
First Name: Vince
Correct - I think we were saying the same thing in two different ways. I only used the Kreg with a 3/4" radius as an example, but you could use what ever radius you want.
Be sure to post some pics when you're done - I'm interested in seeing the finished product - sounds good.
post #7 of 18 (permalink) Old 12-23-2017, 06:16 PM Thread Starter
First Name: Randy
I assumed that we were on the same page.
I will post some photos, but not before I do a bit more wet sanding with the 1500 grit and hit it with the buffer and mag wheel polish.
DaninVan and vchiarelli like this.
ranman is offline
post #8 of 18 (permalink) Old 12-23-2017, 06:52 PM
For simplicity use the same radius as the bit you will use to rout the recess. Or leave it square and then chisel the corners square. Either way works. Whichever you think is easiest for you. It's kind of like the same issue with mortises and tenons. Do you square the mortise or round the tenon? Whichever is easiest. Both work.
vchiarelli and hawkeye10 like this.
post #9 of 18 (permalink) Old 12-23-2017, 08:30 PM
hawkeye10's Avatar
First Name: Don
I vote this to be the best answer but all answers are good.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 18 (permalink) Old 12-24-2017, 08:46 PM
Contributor of the Month
I had a somewhat similar situation. I need to make rounded corner applied edging for a table top. The table top needed its corners radiused and the applied edging needed its inside corners radiused to match the table top corner radius. Plus the applied edging needed its outside corner radiused too. I found an article on the net with instructions on how to make the templates....it involved several steps but the templates came out exact. In your situation I would do the table top radius first assuming you will use the forstner bit or some other available template. Then do the plate to match......a template for the plate is easily done on the router table.
JIMMIEM is offline
New Router Table insert Plate? MT Stringer Table-mounted Routing 2 05-11-2014 09:46 AM
DIY router table insert table orck Table-mounted Routing 4 04-14-2014 07:27 AM
Insert plate vs. Direct bolt to router table Trumanthedog Table-mounted Routing 13 06-01-2010 11:18 PM
