How dangerous is it... - Page 2 - Router Forums
 15Likes
post #11 of 27 (permalink) Old 01-21-2018, 01:08 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
Originally Posted by Herb Stoops View Post
I knew you would figure it out. That is what I was going to suggest.
The bigger OD is no problem but, I just got lucky finding it. Only Klingspor had one of all the sellers I found.
Don, I couldn't find a brass one that size.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #12 of 27 (permalink) Old 01-21-2018, 01:49 PM
JOAT's Avatar
First Name: Theo
Electric drill, piece of dowel, and emery cloth, should enlarge the hole easily enough.
JOAT is offline
post #13 of 27 (permalink) Old 01-21-2018, 03:04 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
Thanks, Theo. That would have been the next thing to try if I hadn't found the bigger one. It's 1 1/32 ID. Just needed it to be big enough to spin a 3/4 bit safely. Not following a pattern so, OD isn't critical.
Gene Howe
Snowflake, AZ
post #14 of 27 (permalink) Old 01-29-2018, 09:53 AM
Honored Member
harrysin's Avatar
First Name: Harry
Originally Posted by Gene Howe View Post
...to spin a 3/4" straight bit in a PC template guide with a 25/32" ID?
Not only can you NOT see what the bit is doing but the likelihood is that the dust will build up and cause lots of heat, not good for the bit! Two reasons why I design most of my templates to use a 40mm template guide. This shot illustrates what I mean.
jw2170 likes this.
Harry
harrysin is offline
post #15 of 27 (permalink) Old 01-29-2018, 11:15 AM Thread Starter
Gene Howe's Avatar
First Name: Gene
Thanks, Harry. I'm just cutting bench dog holes. The reason for the template guide is to be able to use a template that assures accurate spacing.
Gene Howe
Snowflake, AZ
post #16 of 27 (permalink) Old 01-29-2018, 12:28 PM
Nickp's Avatar
First Name: Nick
Forstner bit...?
Gene Howe likes this.
Nick
Nickp is online now
post #17 of 27 (permalink) Old 01-29-2018, 12:55 PM
TWheels's Avatar
Check out Lee Valley: Dog Hole Bushings and Bits - Lee Valley Tools
harrysin and Gene Howe like this.
I Want to Be the Person My Poodles Thought I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #18 of 27 (permalink) Old 01-29-2018, 01:11 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
Thanks, Tom. Definitely worth consideration.
Gene Howe
Snowflake, AZ
post #19 of 27 (permalink) Old 01-29-2018, 07:31 PM
Lee Valley used to sell a cheap French made brad point bit for drilling dog holes. The bit is about 7 inches long give or take. I drilled a hole with it through a short piece of 4 x 4 on my drill press. Then I just laid out the grid on the bench with tape and pencil and drilled free hand just enough to register the tip of the drill in the hole then I ran it through the 4 x 4 and drilled as deep as I could that way. That was maybe 3" deep with one more to go but with the hole that deep already the guide was no longer needed. Worked great and didn't take very long.
post #20 of 27 (permalink) Old 01-29-2018, 11:10 PM
Honored Member
harrysin's Avatar
First Name: Harry
A plunge router using a plunge bit makes the cleanest holes.
TWheels, jw2170 and Gene Howe like this.
Harry
harrysin is offline
Golf can be dangerous harrysin Lobby 14 03-07-2016 07:44 PM
Is this dangerous? Artemix Tools and Woodworking 55 12-21-2015 04:43 PM
Most Dangerous Tool Is...ME! newmexico Shop Safety 11 01-30-2012 08:36 AM
A dangerous idea? matt1710 Table-mounted Routing 7 02-27-2011 04:37 AM
dangerous? newwoodworker Table-mounted Routing 19 04-05-2009 04:13 PM
