How dangerous is it... - Router Forums
 15Likes
post #1 of 27 (permalink) Old 01-20-2018, 08:48 AM Thread Starter
Gene Howe's Avatar
First Name: Gene
Default How dangerous is it...
...to spin a 3/4" straight bit in a PC template guide with a 25/32" ID?
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #2 of 27 (permalink) Old 01-20-2018, 09:28 AM
if you don't mind ruining the bit and the bushing???
Pots43 and Shop guy like this.
post #3 of 27 (permalink) Old 01-20-2018, 09:49 AM
First Name: Richard
Think I would pass.
Shop guy is offline
post #4 of 27 (permalink) Old 01-20-2018, 10:31 AM Thread Starter
Gene Howe's Avatar
First Name: Gene
I figgered a 64th clearance was a bit tight. PC's bushing is steel and the walls look pretty thick. If I had a machinist cut a 32nd from the inside, do you think that would give enough clearance?
Gene Howe
Snowflake, AZ
post #5 of 27 (permalink) Old 01-20-2018, 11:12 AM
TWheels's Avatar
How well can you center the guide? Can you somehow have the bit protruding out of the guide so only the shaft is within it?
Out of curiosity what is the OD of the template guide?
Gene Howe likes this.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is online now
post #6 of 27 (permalink) Old 01-20-2018, 11:57 AM
Any wobble on start up or deflection in use and you are likely to make contact.
post #7 of 27 (permalink) Old 01-20-2018, 12:00 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
I'm cutting 3/4" holes using a template with 1" holes. So, the OD of the guide bushing would be 1".
Gene Howe
Snowflake, AZ
post #8 of 27 (permalink) Old 01-21-2018, 09:40 AM Thread Starter
Gene Howe's Avatar
First Name: Gene
Found a 1 1/4 OD PC bushing that will work. Just need to make the template holes bigger.
Gene Howe
Snowflake, AZ
post #9 of 27 (permalink) Old 01-21-2018, 11:06 AM
I knew you would figure it out. That is what I was going to suggest.
Herb Stoops is online now
post #10 of 27 (permalink) Old 01-21-2018, 11:47 AM
hawkeye10's Avatar
First Name: Don
Don't they make brass bushings???
Don in Murfreesboro,Tn.
hawkeye10 is offline
Golf can be dangerous harrysin Lobby 14 03-07-2016 06:44 PM
Is this dangerous? Artemix Tools and Woodworking 55 12-21-2015 03:43 PM
Most Dangerous Tool Is...ME! newmexico Shop Safety 11 01-30-2012 07:36 AM
A dangerous idea? matt1710 Table-mounted Routing 7 02-27-2011 03:37 AM
dangerous? newwoodworker Table-mounted Routing 19 04-05-2009 03:13 PM
