Someday I'd like to make... - Router Forums
 4Likes
  • 1 Post By kklowell
  • 1 Post By JOAT
  • 2 Post By JOAT
post #1 of 10 (permalink) Old 02-20-2018, 10:03 PM Thread Starter
First Name: Ken
Default Someday I'd like to make...
A perfect template.
I'm working on a router wing for my table saw and made a template to cut out the hole for the insert (which, because I'm cheap and didn't prepare well for retirement) will be a piece of the same material the table top is made of. Because of this, I cut the insert first, traced around it on 1/4 inch plywood and cut that out with my bandsaw. Then I sanded to my traced line. It's going to work, but it wouldn't qualify for any awards for sure. I will say that it's a LOT nicer looking than my first attempt which was just trying to jig saw on a line. All that did for me was generate some scrap.
kklowell is offline
post #2 of 10 (permalink) Old 02-20-2018, 10:19 PM
Semipro's Avatar
First Name: John_*
If it works that is all that counts
Semipro is online now
post #3 of 10 (permalink) Old 02-20-2018, 10:33 PM Thread Starter
First Name: Ken
I know, and I am for sure more about function than beauty, but still, just once I'd like both.
Roy Drake likes this.
kklowell is offline
post #4 of 10 (permalink) Old 02-20-2018, 10:47 PM
JOAT's Avatar
First Name: Theo
You want beauty, then you do what I do. Either modify it, bondo, sanding, cut away some and glue a piece in, whatever it takes, then use that to make a new one. Repeat as needed. OR, start over. Again, repeat as needed. But for things for my shop, as long as it looks decent, it works, then it's normally "close enough is good enough". If a hole really needs to be accurate tho, I use a hole saw, or on occasion, a hole cutter.
JOAT is offline
post #5 of 10 (permalink) Old 02-20-2018, 11:07 PM
hawkeye10's Avatar
First Name: Don
Originally Posted by kklowell View Post
A perfect template.
Ken, maybe this video will help you out.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 10 (permalink) Old 02-21-2018, 12:47 AM
JOAT's Avatar
First Name: Theo
That was interesting. I did my router plate insert totally different, but it is dead accurate anyway. And I had no clue how I did it. Making it was one of those Zen woodworking things, where I know I want to make something, not a clue how, and as soon as I grab a ruler and pencil, then everything pretty much goes blank until it is finished. Get some interesting results that way tho, and so far they all work.
Gene Howe likes this.
JOAT is offline
post #7 of 10 (permalink) Old 02-21-2018, 02:00 AM
JOAT's Avatar
First Name: Theo
This is how I am after Zen woodworking.
Gene Howe and Roy Drake like this.
JOAT is offline
post #8 of 10 (permalink) Old 02-21-2018, 07:24 AM Thread Starter
First Name: Ken
Oh, it is close enough because it is for the shop and it isn't that bad. However, when I do want to make a better whatever, I'll use your suggestions. I honestly hadn't thought of bondo, but I like the idea.
kklowell is offline
post #9 of 10 (permalink) Old 02-21-2018, 07:29 AM Thread Starter
First Name: Ken
Interesting video, Don.That technique would have been so much simpler than what I did. That dude ought to learn about dust masks though!
kklowell is offline
post #10 of 10 (permalink) Old 02-21-2018, 11:08 AM
JOAT's Avatar
First Name: Theo
Some people use bondo in their finished template. Fine for if you are only going to use it once. But with mine about 99% are used more, sometime a lot more. So I just use the bondo (or wood filler, or whatever) to make a really good one, then use that one to make one I will keep. But, for one time use, likely no problem. My templates (masters) are two layers of 1/2" plywood, I like the thickness because, among other things, can get a good grip on it. At times, for the second layer I will glue small pieces on the first, then rout that. Looks ugly as can be when that side is up, but works just as good as a solid piece.
JOAT is offline
How I make my masters/patterns/templates JOAT Project Plans and How To 0 08-13-2017 01:05 AM
Learning How to Make a Tissue Box Cover learnexperience General Routing 2 12-05-2011 06:56 PM
How to Make a Picture Frame learnexperience Table-mounted Routing 10 09-24-2011 05:48 AM
How to Make Wheels learnexperience General Routing 7 09-08-2011 10:27 AM
How to Make a Raised Panel Door learnexperience General Routing 2 09-06-2011 09:39 PM
