Making dishes - Router Forums
 7Likes
  • 5 Post By harrysin
  • 1 Post By JFPNCM
  • 1 Post By Herb Stoops
post #1 of 9 (permalink) Old 02-26-2018, 08:47 AM Thread Starter
Default Making dishes
I have a 3/4" dish bit and a bit extension. My problem is if I try to make a deep bowl/dish the collet nut is larger than the bearing (3/4") so it hits the pattern or edge of the dish and I can only go about 1-1/8" deep. With the extension I thought I would be able to go about 3" deep. What do I do to get a deeper dish?
Fatcat161 is offline
post #2 of 9 (permalink) Old 02-27-2018, 06:42 AM
difalkner's Avatar
First Name: David
Welcome to the forum! When you get a minute go ahead and complete your profile with first name and location. This help us to get to know you and to better help you. You can post photos now if they're on your computer but you can't link to 3rd party hosting until you have more than 10 posts.
Upload some photos of what you're doing on the dish and that might help to get some suggestions.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #3 of 9 (permalink) Old 02-27-2018, 08:40 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
This pdf of one of my past projects should give you an idea of how I do deep routing. the "secret" is to use a LARGE template guide, I use a 40mm one (about 1 1/16") this allows the chuck and the extension to pass through it giving a much deeper cut.
Harry
harrysin is offline
post #4 of 9 (permalink) Old 02-27-2018, 10:24 AM
MEBCWD's Avatar
Will a 1 1/8" bowl bit be bigger than the collet nut? Measure across the points of the nut. If it is still too small then Harry's technique would be a good solution.
MEBCWD is offline
post #5 of 9 (permalink) Old 02-27-2018, 12:46 PM Thread Starter
Harry, my template isn't adjustable so I can't make if larger to accommodate an oversized bearing.
Mike, from what I read a 1 1/8" bit would require a 1/2" shank and the extender for them uses a 28mm wrench. I expect the nut to be a little larger so it will be close if not larger than 1 1/8". Also, a larger bit won't get into the corners.
Keith
post #6 of 9 (permalink) Old 02-27-2018, 01:30 PM
Keith
I have used a bowl bit with a bottom bearing,( that guides against the template) and no bushing required. when the bit goes deep enough so the bearing clears the template then it rides against the sides of the bowl to guide the edge cut.
https://www.amazon.com/CMT-851-002-1...SIN=B000P4O5YI
Herb Stoops is online now
post #7 of 9 (permalink) Old 02-27-2018, 09:01 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is online now
post #8 of 9 (permalink) Old 02-27-2018, 09:06 PM
JFPNCM's Avatar
First Name: Jon
I've been very pleased with the CMT bit/extender combination for making bowls. Mine is similar to Herb's but with a 1/2' shank. I also use the smaller bowl sanding kits that allow one to finish in the tighter corners etc.
Herb Stoops likes this.
Jon
JFPNCM is online now
post #9 of 9 (permalink) Old 02-27-2018, 10:16 PM
I remove the bulk of the material on the drill press with large forstner bits staying well away from the finished edge. Then go in with the router and clean it up.
The forstner bits have a short pilot point in the cutter,so I learned to allow for that in the depth so the little dimples could be removed..
I used those small discs and a drill motor to sand the bottoms out, being careful to stay away from the edges. Those I cleaned up with a sanding mop.
JFPNCM likes this.
Racetrack molding - Making rings for curved trim Shells Tools and Woodworking 5 03-09-2014 08:42 PM
Making a cam board... jw2170 Jigs and Fixtures 10 12-27-2013 07:01 PM
New Member making Chairs Tracy White New Member Introductions 3 09-29-2009 01:08 AM
Making puzzles, looking for a jig idea kweinert Jigs and Fixtures 3 08-31-2009 07:59 AM
