Guide bushings or bearing guided? - Page 2 - Router Forums
 15Likes
post #11 of 24 (permalink) Old 04-03-2018, 01:01 PM
First Name: Mark
You could also just make your own router base to fit the Porter-Cable style bushing.
harrysin likes this.
MYB506 is offline
post #12 of 24 (permalink) Old 04-04-2018, 01:39 AM Thread Starter
1fizgig's Avatar
First Name: Steve
Thumbs up Thanks Biagio
Originally Posted by Biagio View Post
Steve,
living under the same limitations of choice of the Southern Hemisphere (compared to our North American friends), here is my take:
1. unless the bearing is a complete dud, the concentricity of bearing and bit is a given; the centering of the bushing, not so much. The so-called universal base plates seem to be less than universal.
2. It is possible to use a bearing/bit combination on a PC type of dovetail jig; similar caveats will apply as for a bushing:
- make sure that the bearing OD fits between the template fingers;
-the correct depth of the bit does not locate the bearing above (disastrous for the template) or below the fingers (disastrous for your workpiece);
-the bit has the correct length and dovetail angle recommended for the jig;
3. Whatever you do, do not lift the router off the jig while the bit is spinning.
4. Since you have not purchased a jig yet, if Milescraft sell in Oz, i would recommend you look at their dovetail template-making master-jig. It allows you to make your own jigs, of whatever size you want, in two styles: PC style, and also Katy-style, such a Tom is using on his router table, above. You will need a straight bit, a dovetail bit, and their bearings. A centre-finding ruler will speed things up, but is not essential. Since the jigs are made of MDF, if you forget not to lift off with a spiining bit, worst case you have messed up some MDF. Also good for box-joints.
That Ryobi is a nice-looking bit of kit -has not been released here yet. I have had two of the predecessor 1600RE - only problem I had was bit slippage with 1/4in. shafts.
I appreciate your insights. Yes, we southern-hemisphered people do not seem to have the range sadly, and it does make things a little frustrating. Postage costs are also often prohibitive.
I'll look up that Milescraft kit - it may be that one of the local suppliers can source it at a reasonable price for me.
1fizgig is offline
post #13 of 24 (permalink) Old 04-04-2018, 01:47 AM Thread Starter
1fizgig's Avatar
First Name: Steve
Thumbs up Thanks Tom
Originally Posted by DesertRatTom View Post
My Katey jig came with the two bits so I didn't have to buy them.
No table? That's a pretty easy fix. Make your own. For cutting dovetails and many other tasks, you can get good results with a piece of good quality ply (you can get a piece of Baltic Birch ply or something similar, from a local supplier. You cut an opening in the ply and mount the router underneath. If you want to use it for the long haul, add a second layer or 18mm wide, straight stock as trusses underneath.
If you have almost any kind of cabinet, you can mount the top on it, or simply set on top of a couple of saw horses. I'd mount a switch on the underside of the top so you can easily turn the router on and off.
If you use two layers, cut an opening large enough for the router base in the bottom layer and attach the two with screws. Two layers help keep the top flat over time. Later, you might wish to put in a mounting plate, and the double layer will make that easier. Also, you can use a really flat 2x4 or 2x6 as a fence. You clamp it in place. Cut an opening for the bit and maybe a dust collection port at the back side of the opening. Simple to make, very serviceable. It is also safer in general to use a router in the table. Your mate may appreciate that.
Lots of posts on making a router table on the site. The Porter Cable type jig is less expensive in general than the Leigh/Sommerfeld (L/S) units, but one reason I'm selling my never used Rockler jig is it is very confusing to correct an effor in the result--at least it is to me. As you saw in the video, how intuitive the L/S jig is. You number the parts as shown and set height very simply and you've got it. Both L/S jigs also have straight box joint "tuning forks." The Sommerfeld "new" dovetail jig is $240 (U.S.), bits included, not very much more than the Porter Cable style jig. I think you'll be happier with the L/S style jig.
https://sommerfeldtools.com/professi...s-dovetail-jig
Thanks Tom, as always, sage advice, I appreciate it.
A table is on the "to do" list, although it'll likely be one I can pack away easily as I don't have the room for another table in my garage currently
My only thing about doing a table is the higher likelihood I'll want a dedicated router to fit it - would just make life easier - but that might need to wait until I've got enough brownie points to swing that past my wife
I've picked up a few router table designs, including looking at some in the forums, so I think I'm spoiled for choice in that area.
DesertRatTom and jj777746 like this.
1fizgig is offline
post #14 of 24 (permalink) Old 04-04-2018, 01:51 AM Thread Starter
1fizgig's Avatar
First Name: Steve
Default Thanks Andy, but...
Originally Posted by DonkeyHody View Post
I think it's time to bite the bullet and buy another router even though you said it's not an option at this time. Delay the purchase of a dovetail jig if you have to. You'll find it very handy to have a second router in any case. Dovetail jigs are fussy and you're setting yourself up for frustration if you try to build a base that centers the bushing with the accuracy required. My $0.02 worth, your mileage may vary.
I don't have the budget right now for something that would suit this, and the used market here isn't great even if I went that way (not keen for a router unless I know the history, it's too risky IMHO).
But I hear what you're saying about the base. I think we could all go round all day on how reliable it is. Harry's obviously built his own with some success based on what I've seen, but I'm not sure I've got enough confidence to get it right
1fizgig is offline
post #15 of 24 (permalink) Old 04-06-2018, 12:18 AM
Country: South Africa
First Name: Biagio
Steve, a limited budget (with which I have been painfully familiar most of my life) is no impediment to doing what you want - some of the best ideas on this forum involve improvisation. I second Tom - for getting your feet wet, a simple board on any stand is adequate, and if you use the Katy-style jig, a fence is not required ( alertness and safety-consciousness is, however, essential). If you have one of those folding Black and Decker Workmate type of portable benches, there is a very simple plan on Pinterest. For about 15 years, a similar setup served me adequately for my limited capabilities.
I have a larger version of Harry’s jig (BTW, no special sub-base required, he is showing a 1/4 inch shank bit in a 1/2 inch adapter), but since going with the simplicity of setup that Tom refers to with the Katy-style, it has been gathering dust. As an anal-retentive type, I hate parting with tools, even unused ones.
I have two major gripes with the world: the 220-110 volt divide ( I believe thanks are due to Mr Edison), which means our power tools are about 50% more expensive, and driving on the wrong side of the road ( not sure who to thank) which means our cars are 30% more expensive. And if you think it is bad your end, concole yourself that eight of ours equals one of yours.
1fizgig likes this.
Biagio is online now
post #16 of 24 (permalink) Old 04-06-2018, 12:46 AM
JOAT's Avatar
First Name: Theo
I tried a bushing once. Didn't care for it. Bearings serve me well, and I'll just stick with them. But, your money, your call for yourself.
JOAT is offline
post #17 of 24 (permalink) Old 04-07-2018, 01:41 PM
Sounds like you have more time than money, in which case, one router will have to do. You don't need a lift either. For me the PC jig vs. the Katey style jig is a matter of remembering how to adjust the PC style jig--I can't seem to get it down pat and I've retired my Rockler/PC jig. So when you get the spousal OK, I'd get the Katey style, which includes the bits. Really about the same cost as the PorterCable jig alone. Having semi retired, I know how money can get tight. A flat chunk of ply will make an adequate router table top. You could also repurpose an old table from a thrift store. It's no big deal to mount the router in the top only when you need it, that's a workable choice if you have more time than money.
DesertRatTom is online now
post #18 of 24 (permalink) Old 04-08-2018, 07:25 PM Thread Starter
1fizgig's Avatar
First Name: Steve
Default Ah to dream...
Tom, I may get more funds if I build some things that can be sold
Self-funding hobby is going to be the easiest way for me to expand my options.
As it stands, I suspect I'll look to build something simple but functional as my first table and go from there. I'm not sure how the power part works - how do you add an external power switch to your router without messing with the controls built in?
Anyway, that's probably a separate conversation.
I thank you for your contributions, I'll keep my eye out for a Katey-style jig at reasonable price (over here).
DesertRatTom likes this.
1fizgig is offline
post #19 of 24 (permalink) Old 05-08-2018, 09:11 AM
First Name: Reuel
Default You only need an adapter
Hi Steve
Something like:-
https://www.carbatec.com.au/joinery-...aptor-lgh-704r
Triton, Hitachi, Ryobi, Trend use a 60mm holder of their Guide Bushes.
With an adapter, that has a 30mm hole, ALL Porter Cable Guide bushes can then be used.
Alternatively you can get the Triton Guide Bush kit that has guide bushes of same (imperial) sizes as the Porter Cable set and also includes an adapter to take more Porta Cable Guide type brass bushes.
(I have one set of the Triton Guide Bush kit and use them on my Hitachi Router.)
Reuel
reuelt is offline
post #20 of 24 (permalink) Old 05-08-2018, 09:15 AM
First Name: Reuel
Hi Steve
Check whether this is compatible:-
(I have one set of the Triton Guide Bush kit and use them on my Hitachi M12V Router.)
Reuel
reuelt is offline
Rockler Signmaker Guide Bushings KennK Guide Bushings and Templates 1 09-16-2017 07:48 PM
how to setup bearing guided cutters roman ogee in r/table please matey Table-mounted Routing 5 08-04-2012 05:07 PM
Metric bits and guide bushings Mike The Voting Booth 29 05-09-2012 10:08 AM
Where to find a ball bearing guide attachment mountainbikeak Guide Bushings and Templates 1 02-15-2012 03:45 PM
Guide bushings Tazkb Guide Bushings and Templates 3 11-22-2011 11:31 AM
