Sub base - Router Forums
 1Likes
  • 1 Post By reuelt
post #1 of 3 (permalink) Old 06-15-2018, 02:33 AM Thread Starter
Weh2k9's Avatar
First Name: Jacob
Default Sub base
Hello all, I have the Triton mof001 and I'm looking to get a sub base and some guide bushes for a project. I have been looking at trend bases and bushes as recommended from you guys. I have found conflicting information as to what base fits the mof001 and I'd be very grateful of someone could clear up for me which one to buy, and whether I'd need to drill it to make it fit? I'm also curious do all trend guide bushes fit all the sub bases. Thanks.
Weh2k9 is offline
post #2 of 3 (permalink) Old 06-19-2018, 12:25 PM
First Name: Reuel
Default Why not buy the TGA250?
Template Guide Kit 12pce | TritonTools.com
(It can be bought from Amazon UK)
After the #9 item of the TGA260 is fitted to your MOF001, you can use then Trent Metric guide Bushes.
If you fit the no 11 (alignment Bush from TGA260) to the #9, you will then be able to use BRASS Porter Cable style Imperial Guide Bushings but they will be redundant since they will be the same size as #1 to #7 of TGA250.
The #8 of TGA250 is the only metric guide bush (30mm) included. This allow you to use with COOK TOP JIG or other templates jigs sold commercially.
DesertRatTom likes this.
reuelt is offline
post #3 of 3 (permalink) Old 06-19-2018, 06:46 PM
First Name: Reuel
The sub base recommended by US Router Forum Members is for Brass Porter Cable screw on type Guide Bushings. Trent's (60mm steel plate mounted) guide buses will not fit.
If you want to use Trent Guide Bushes, you will need a sub base made by Trent or Axinister.
Trent's Guide Bushings are mostly metric whereas Porter Cable Guide Bushings are all IMPERIAL sizes.
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
Question about new DeWalt DW 611 router LBrandt General Routing 29 09-01-2017 10:55 AM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
The Marvel 3 in 1 tool from MLCS: base plate and table mount advice please loninappleton Table-mounted Routing 4 07-10-2010 08:32 PM
Craftsman 17543 Combo Fixed Base Height Adjustment Gator95 General Routing 14 11-29-2008 03:30 PM
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 07:54 PM
