Bosch template depth of cut - Router Forums
 7Likes
post #1 of 19 (permalink) Old 09-10-2018, 11:58 AM Thread Starter
First Name: Pete
Default Bosch template depth of cut
Hello all. I use to come to this forum years ago but recently restarted woodworking. I do have a question. I am using the Bosch 1617EVS plunge router to do a router table insert (off the Jessem template). I have the Bosch template guides but the bit I am using is only about 2 1/2 long and won't get much further than a 1/16" past the Jessem template. The Bosch adapter seems to limit depth. Are there router bits that are longer that might work? I also have a set of PC guides but they are too small for the Bosch without the adapter.
I am regretting getting the Bosch and might get rid of the system and go with another brand (maybe DW618pk).
Thanks in advance for any response.
Pete
psal217050 is offline
post #2 of 19 (permalink) Old 09-10-2018, 12:18 PM
If I'm reading right, you could probably just use a bit with a bearing to follow the template. I don't think you get any advantage using a bushing. How thick is the template? Most templates are no more that 3/4 inches thick, so if you drop the router motor down low, with a bearing on a mortising bit, you should easily be able to cut a half inch rabbet to hold your table insert plate. You'll want to use plate height adjustment screws in the corners so you can get the plate even with the top. See Pix of example mortising bit and router plate leveler from Kreg. You shouldn't need more than an inch long bit. I did this recently with a 3/4 inch MDF template from Woodpecker and a trim router. The 1617 should easily handle removing 1/8th or so for four passes. Clamp the template down firmly or at least use double stick tape.
Name:	router plate levelers.jpg
post #3 of 19 (permalink) Old 09-10-2018, 01:02 PM Thread Starter
First Name: Pete
It looks like if I use a pattern bit (I have a 1/2" from Rockler), I might make the opening about 1/4" too big (1/8" on all sides). I think this is why Jessem recommended the 3/4" OD bushing with 1/2" straight bit. I need to do this outside and it has been raining here for 3 straight days. Once it clears, I will do a test cut on scrap plywood with just the 1/2" pattern bit and try the router lift in that. If it is too big, then I will need to go back to the guide. If it fits, I will do it in the table saw insert.
Currently, the table saw insert is 2 MDFs laminated together. I am new here so I can't post a pix yet.
Thanks for the suggestion.
Pete
post #4 of 19 (permalink) Old 09-10-2018, 02:11 PM
Pete you can post pictures as long as they are from your hard drive and not a link to a photo sharing site. Use the Go Advanced posting option and below the text box look for Manage Attachments. If you need more help thatn that let me know.
There is one other method some members use to rout out the recess for a plate. They take the plate and lay it on the table where they want it and then take strips (wide enough for the router to sit on is best) and using double sided tape they stick them down against the side of the plate so that they form an outline the same size as the plate. Then remove the plate and use a mortising bit with bearing to rout the lip that the plate will sit on. Depending on the diameter of the bit you use and the radius of the plate corners you may have to trim them up a little. If you are lucky enough to have a bit with the same radius then it should drop right in after.
post #5 of 19 (permalink) Old 09-10-2018, 02:29 PM Thread Starter
First Name: Pete
Thank you. I was temped to do that but then spent the money on the Jessem template and I really hate to waste the money spent. I saw a Bosch router bit that is 1/2" shank, 1/2" straight bit and 4.5" in overall length and was temped to get it to work with the Bosch template guides. It seems to be a little long but I am willing to try it. It was at Lowe's and is Item # 27834 Model # 85252MC. Not sure I want to spend more and even thought about cutting the template into 4 (1/8 blade on saw) and then putting it back together to use it with the pattern bit that I have. That might work too.
post #6 of 19 (permalink) Old 09-10-2018, 04:51 PM
A picture would really help. You are using some terms that apply to other equipment. Does your router template have a hole in the middle the size of your router plate? Or is it different? I can't quite make out exactly what you're trying to do. I have used the method illustrated below to rout out an opening for a plate. Four pieces of wood a quarter to half inch thick. Place the plate itself where you want it to go. Place the four pieces as shown and clamp the at the edges of the table. You can then use a bearing guided bit.
Mark out an opening about half an inch smaller than the plate on the wood. Cut that opening out with a jig saw before you try to cut the opening using the template.. That will allow you to cut with the mortising bit rather than trying to get a bit to plunge into the flat surface. As I think about it, I'm not sure if you've skipped that step of cutting out the smaller opening? If not, that's your problem, not the adapter.
Remove the adapter from the router, put in a mortising bit and (in 1/8th increments) rout out to a little deeper than the thickness of the plate. I added some very thin plywood between the plate and the four pieces to allow a little wiggle room to get the plate out easily. I strongly suggest you use the Kreg levelers.
You don't have to cut through the entire thickness of your table. Leaving a half inch lip for the plate to sit on will work just fine. Do use the Kreg levelers, you'll have a much easier time leveling the plate with the table top. I suggest you get a plate with the twist lock insert ring mechanism rather than the older kind that has multiple screws, which are annoying and easy to lose.
Name:	router plate frame.jpg
Name:	SIZING ROUTER PLATE OPENING.JPG
Gaffboat likes this.
post #7 of 19 (permalink) Old 09-11-2018, 06:52 AM Thread Starter
First Name: Pete
Thanks for the info. I was able to make an adjustment, but the bit will be just short of the depth I need. If I had a slightly longer bit, I should be able to use the template. The only issue I am not sure about is at the max depth, the collet appears to touch the Bosch adapter/template guide. So, I switched to the PC adapter in the Bosch adapter (too many adapters). As far as the template, there is an approximate 1/8" void around the lift using the template (which is ĺ” MDF from Jessem).
post #8 of 19 (permalink) Old 09-11-2018, 07:40 AM
TenGees's Avatar
First Name: Paul
Pete, I'm not sure of your experience level but the bit doesn't need to be (and shouldn't be) bottomed out in the collet. If you use a bearing bit, the bearing would have to be 1/4" (diameter) bigger than the bit, to work with that template. I would definitely try it out on a scrap first.
TenGees is offline
post #9 of 19 (permalink) Old 09-11-2018, 08:54 AM Thread Starter
First Name: Pete
Appreciate the response. Experience level with routers is just north of beginner. With table saw and other items 10+ years. I am just using a straight bit. I have a 1/2" pattern bit but not a larger bearing to use on it. If I did, I would definitely do it that way.
Do you have a source for bits with various size interchangable bearings?
post #10 of 19 (permalink) Old 09-11-2018, 09:46 AM
TenGees's Avatar
First Name: Paul
The ones that I've seen have a screw to lock the bearing to the shaft (see the pic in post #2 by Tom). So I believe you could use a 3/4 bearing on a 1/2 bit. I would try the guides if you can get the depth sorted out. I don't know the US suppliers but here's Lee Valley: Template Bits - Lee Valley Tools
TenGees is offline
Hello! drcoyle New Member Introductions 26 06-30-2018 07:13 PM
Hello OBG65 New Member Introductions 20 05-06-2018 10:34 PM
Hello all Weh2k9 New Member Introductions 13 05-02-2018 05:45 PM
Xmas - I got a Triton TRA001....now what table? mikeyo76 New Member Introductions 10 12-26-2017 04:13 PM
Another Newby Tweety New Member Introductions 13 12-18-2017 06:38 AM
