Small cut-out in thin template - Page 2 - Router Forums
 15Likes
post #11 of 14 (permalink) Old 11-05-2018, 04:02 AM
Honored Member
harrysin's Avatar
First Name: Harry
Originally Posted by DesertRatTom View Post
I'd probably start with laying out the cutout, finding center then use a large Forstner bit to hog out the center. Then some smaller bits in the four corners, then chisels for the rest. I'd probably leave it a little proud then some sandpaper on a block to perfect the sides and corners. But the best way to do this would depend a lot on your tools. If I used a chisel in the corners, i'd sharpen the heck out of it first, and I'd scribe the line so it didn't splinter.
I also might choose to use four guide boards as Harry suggests to rough cut the center opening. Cut the outside dimension with the table saw, then lay four boards close around it to define the opening and use a bottom bearing trim bit to cut the inner opening, and use sandpaper to perfect the opening. This would only work if you have your bit perfectly centered. I'd use a trim router because it's smaller and more manageable. You'd have to place the guide boards so the inside cut was accurate, or a little proud so you can sand it flat.
This is definitely going to depend on what tools you have. Or, take it to a local CNC shop and get it done quick and easy.
Lots of ways to skin this cat.
Tom, the four pieces ARE the template. As shown in one of the shots, the simple formula to calculate the size of opening in the template is: dia. of template guide minus diameter of the bit plus the size of the finished project.
Harry
harrysin is offline
post #12 of 14 (permalink) Old 11-07-2018, 09:01 PM
First Name: ben
I agree with harrysin's suggestion. I used this technique on jigs that require square corners as in the attached photo of a band saw jig for cutting an inside radius.
Name:	inside radius bandsaw jig.jpg
harrysin likes this.
bfblack is offline
post #13 of 14 (permalink) Old 11-08-2018, 01:04 AM
beserkleyboy's Avatar
I vote for Harry's idea. I use that very idea for lots of things. If concerned about joining the 4 pieces, just fasten another overlapping layer on top. Masonite or MDF is perfect. I use 23ga headless pinner to fab jigs and such. With this method, you could have a template in 10 minutes flat...cheers, guys
Jim Pearson
30 yr expat in AUS
beserkleyboy is offline
post #14 of 14 (permalink) Old 11-08-2018, 07:48 AM
Needing to cut some slots of the legs for my adjustable workbench, I made this jig from 1/2" MDF - as said, takes about 10 minutes (plus drying time). I made extra length of the center block once I had the perfect fit on the guide bushing so I can make more in the future.
harrysin and Stick486 like this.
tomp913 is offline
BOSCH 1617EVS mounting on a router table ironman21 Table-mounted Routing 59 10-31-2018 06:15 PM
What about that newbie? 1fizgig New Member Introductions 45 03-18-2018 09:02 PM
Advice for a Router and/or lift AnotherOldJarhead General Routing 27 02-27-2018 10:16 AM
Advice on Cable Grommet Techniques plunger Starting Off 13 10-03-2015 02:03 AM
Weatherwatch derek willis Show N' Tell 10 03-16-2011 08:21 AM
