Small cut-out in thin template - Router Forums
 15Likes
post #1 of 14 (permalink) Old 11-04-2018, 12:32 AM Thread Starter
First Name: Dale
Default Small cut-out in thin template
I have a piece of 1/4" hardboard cut to 6x12". My challenge is to get a perfectly centered 4x4" square cut out, with smooth edges and sharp corners. It will be a template. I don't want it to take forever. The layout is no problem, just getting straight and smooth sides. The ol'saber saw is not smooth enough. Any ideas? I thought about routing, but I'd need a template to make a template
DaleFiorillo is offline
post #2 of 14 (permalink) Old 11-04-2018, 12:39 AM
plunge cut a template w/ a table saw ....
cut the final w/ a router from the template or just use the plunge cut piece...
post #3 of 14 (permalink) Old 11-04-2018, 12:49 AM
MT Stringer's Avatar
I have done that exact thing. Used double sided tape to stick pieces of mdf around the layout. Then use the jig saw to cut away most of the waste. Next, use a 1/4 inch pattern bit to rout the inside of the temporary template by following the mdf with the bearing on the pattern bit. Then you will have to hand trim the corners.
Think about it, maybe do a test or two on scrap, then go for it.
Good luck.
FYI - here are some videos to check out.
https://www.youtube.com/results?sear...ate+for+router
TenGees likes this.
MT Stringer is offline
post #4 of 14 (permalink) Old 11-04-2018, 07:49 AM
john60's Avatar
plunge cut with multipurpose tool with square blade or find someone good with scroll saw
john60 is offline
post #5 of 14 (permalink) Old 11-04-2018, 07:57 AM
Danman1957's Avatar
Dale,
Is there a local laser cutting company close by, this would be so easy for them, I can't imagine they would charge too much and it would be very precise.
Dan
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #6 of 14 (permalink) Old 11-04-2018, 08:04 AM
CharleyL's Avatar
First Name: Charley
I frequently cut needed templates with my scroll saw. Perfectly straight cuts are a little difficult on a scroll saw, but the error is usually so little that a sanding stick will straighten it with just a few strokes. The scroll saw cuts so clean that I rarely need to do anything else before putting it into use.
Charley
hawkeye10 likes this.
Central North Carolina
CharleyL is offline
post #7 of 14 (permalink) Old 11-04-2018, 09:27 AM
Honored Member
harrysin's Avatar
First Name: Harry
In my years of experience of template making this is the only way to make a perfect "cutout" Modern adhesives will certainly hold the four pieces together even with hardboard.
Barry747, MEBCWD, Gaffboat and 6 others like this.
Harry
harrysin is online now
post #8 of 14 (permalink) Old 11-04-2018, 12:21 PM
Garyk's Avatar
First Name: Gary
A cross cut sled on a table saw would work IF you have one straight side to begin with. If no side is straight you can make a sled that goes against the fence from a piece of plywood (factory edge) with a few hold downs that gives you a straight cut to have a good side to start with. Posted in 2013: http://www.woodworkingtalk.com/f27/s...rip-jig-40532/
Down the road such jigs come in handy so the moral of this story is you never have too many jigs.
Garyk is offline
post #9 of 14 (permalink) Old 11-04-2018, 12:53 PM
I'd probably start with laying out the cutout, finding center then use a large Forstner bit to hog out the center. Then some smaller bits in the four corners, then chisels for the rest. I'd probably leave it a little proud then some sandpaper on a block to perfect the sides and corners. But the best way to do this would depend a lot on your tools. If I used a chisel in the corners, i'd sharpen the heck out of it first, and I'd scribe the line so it didn't splinter.
I also might choose to use four guide boards as Harry suggests to rough cut the center opening. Cut the outside dimension with the table saw, then lay four boards close around it to define the opening and use a bottom bearing trim bit to cut the inner opening, and use sandpaper to perfect the opening. This would only work if you have your bit perfectly centered. I'd use a trim router because it's smaller and more manageable. You'd have to place the guide boards so the inside cut was accurate, or a little proud so you can sand it flat.
This is definitely going to depend on what tools you have. Or, take it to a local CNC shop and get it done quick and easy.
Lots of ways to skin this cat.
DesertRatTom is online now
post #10 of 14 (permalink) Old 11-04-2018, 12:55 PM
I'd probably start with laying out the cutout, finding center then use a large Forstner bit to hog out the center. Then some smaller bits in the four corners, then chisels for the rest. I'd probably leave it a little proud then some sandpaper on a block to perfect the sides and corners. But the best way to do this would depend a lot on your tools. If I used a chisel in the corners, i'd sharpen the heck out of my chisel first, and I'd scribe the line so it didn't splinter.
BOSCH 1617EVS mounting on a router table ironman21 Table-mounted Routing 59 10-31-2018 06:15 PM
What about that newbie? 1fizgig New Member Introductions 45 03-18-2018 09:02 PM
Advice for a Router and/or lift AnotherOldJarhead General Routing 27 02-27-2018 10:16 AM
Advice on Cable Grommet Techniques plunger Starting Off 13 10-03-2015 02:03 AM
Weatherwatch derek willis Show N' Tell 10 03-16-2011 08:21 AM
