Router Forums (https://www.routerforums.com/forum.php)
-   Guide Bushings and Templates (https://www.routerforums.com/guide-bushings-templates/)
-   -   Need ideas for an inlay project (https://www.routerforums.com/guide-bushings-templates/137837-need-ideas-inlay-project.html)
Mickeyfolse 02-22-2019 12:03 PM
I am looking for guidance on what to do for the outer border surrounding this fleur de lis. I already have one idea but it doesnít involve trying to inlay something in a groove.... simply because i donít know what to try putting in there even if Iím successful at cutting an accurate groove around it. And i feel Iíd need to be a magician or have a laser cutter to cut the inlay piece(s).
So basically Iím looking for ideas here on how to handle this outline.
https://uploads.tapatalk-cdn.com/201...7871b5384f.jpg
https://uploads.tapatalk-cdn.com/201...8222516cd4.jpg
Sent from my iPhone using Tapatalk
difalkner 02-22-2019 12:21 PM
Go to StewMac or Luthiers Mercantile and look at the binding and purfling for guitars. You'll find plenty of choices for that outline. You'll be able to glue it on and use a razor saw to cut the miters at the points.
David
Danman1957 02-23-2019 09:44 AM
The Fleur De Lis is on our flag 4 times (Quebec, Canada) I love it. Do you really need a border, I find it looks good as is.
Mickeyfolse 02-23-2019 01:48 PM
I kinda want the border, yes. It looks ďskinnyĒ as it is. I actually had to print it out without the border to see if i had screwed up somehow. But nah thatís how it is. The border really messes with your head and changes the look. Besides, itís a New Orleans Saints piece, and their fleur de lis has the border lol.
I also sanded the edges of my stencil some more to make it a bit smoother next time. I also have to trim the edges of the stencil card slightly so things line up a little better.
Mickeyfolse 02-23-2019 01:50 PM
David
I ordered some of this and will certainly try it out. Looks like a very nice solution! Thanks!!!
Tagwatts1 02-23-2019 07:54 PM
Sir,
I saw something somewhat similar. I will try and explain it to you. It was a diamond shape set inside a circle. The Circle was large enough that an inlay could go all around the diamond edges. The circle had the inlay on both the inside of the circle and the outside of the circle. The top and bottom of the diamond inlay and the inside circle of the inlay all just touched at the points of the diamond. All of this was done on a C N C machine. A 1/8 in bottom bit was used to create the Diamond Shape. The inlay was created using 30 degrees by 60 degrees bit. The diamond shape was only one eight of an inch deep. The Inlay cuts were just a bit deeper. Within diamond, he had inscrolled the letters, To (her name) All My love (his name) and the date was inscrolled as well. It was very well done and really beautiful. I do not remember, but I think there may have been a pocket cut made over all the full of the diamond area.
This was all set up on base at the bottom of the wood. This project was not cut all the way through at any point.
Sir,
Mickeyfolse 02-23-2019 10:00 PM
Well, i don't have a Cnc machine and I'm not really following what you're trying to describe. I am curious to try to understand though!
Mickeyfolse 02-26-2019 04:40 PM
David
Worked out very nicely!!! Thank you!!!
https://uploads.tapatalk-cdn.com/201...c5cbe1abde.jpg
difalkner 02-26-2019 05:46 PM
Excellent! Looks good, too. Good job.
David
Powered by vBulletin® - Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
