looking for guide bushing baseplate for Bosch 1617EVS - Page 2 - Router Forums
 17Likes
post #11 of 24 (permalink) Old 08-30-2019, 10:45 AM
FYI, the centering cone fits in the collet just as if it were a bit, so it is automatically centered to the bit.
jj777746 likes this.
DesertRatTom is online now
post #12 of 24 (permalink) Old 08-30-2019, 01:21 PM
CharleyL's Avatar
First Name: Charley
I center my DeWalt router base plates with the centering pin/cone provided by DeWalt, but to hedge my bet when using my Leigh D4R dovetail jig, I also placed a marking pen arrow on the top of the router bases. When cutting dovetails I always point the arrows toward the jig when making the cut. A slightly off center guide will then cause the entire joint to be shifted left or right just slightly, and I always trim off the board edges a little anyway. If a slightly off center guide bushing is used, and you rotate the router base while cutting dovetails, it will cause errors withing the joint. Keeping the router always pointed the same way keeps the joint accurate, but may cause a slight shift one way or the other.
Charley
Central North Carolina
CharleyL is offline
post #13 of 24 (permalink) Old 08-31-2019, 12:41 AM
I use a Jasper M400, and it has holes for the Bosch 1617....
Sydney, Australia
jw2170 is offline
post #14 of 24 (permalink) Old 08-31-2019, 02:37 AM
Semipro's Avatar
First Name: John_*
you will have to make one yourself or get a universal plate.
Bosch. does not make a PC guide plate for the plunge base.
Probably because PC guides are used with templates and most people use a solid base with them.
Herb Stoops likes this.
Semipro is online now
post #15 of 24 (permalink) Old 08-31-2019, 02:46 AM
That is what I think too, John.
I did buy the bosch set of bushings for my plunge base, I haven't used them yet ,but was not impressed with the cheapo sheetmetal construction when I recieved them.
Nickp and jj777746 like this.
Herb Stoops is online now
post #16 of 24 (permalink) Old 09-02-2019, 07:34 AM
https://www.leightools.com/guide-bushings-adaptors/
Stick486 is offline
post #17 of 24 (permalink) Old 09-02-2019, 10:09 AM
CharleyL's Avatar
First Name: Charley
Won't this work? It says that it does.
https://www.amazon.com/Bosch-RA1129-...G89EY1VQH5FKY4
Charley
CharleyL is offline
post #18 of 24 (permalink) Old 09-06-2019, 12:05 PM Thread Starter
As a follow up.
I did try the Bosch quick release set up that came with my Bosch 1617EVS kit, and which I mentioned that I already own, but thought it looked ill conceived, kludgy and klutzy. I have confirmed to myself that the Bosch OEM quick release bayonet mount holds the Bosch OEM template guide in a loose fitting sloppy manner. This system seems like a bad idea that was manufactured poorly.
I received the Jasper M 575B universal plate and installed it on both the RA 1166 plunge router base and RA 1161 fixed base that came with my Bosch 1617EVS kit. The mounting holes do line up with the respective bases, but not in a position that allows for proper concentric mounting of the Router Template Guide. The correlation between the mounting holes is "off" by a good margin which makes the base unsuitable for the task which I purchased it for. I was able to attach one mounting screw and rotate the plate so that the center hole was centered but then the other two mounting holes were not available for use.
I purchased a Bosch RA1151 Router Sub base Centering Device and found that after careful assembly the conical mandrel exhibited run out that was easily visible without the use of measuring indicators. The Bosch centering device does not help find the center, it just sort of looks like it does.
The Jasper plate came with an included aluminum mandrel, which promised "precision" in its description. It too exhibited run out that precluded its usefulness.
FWIW, I have been asking about using a guide bushing with a Plunge Base, because I would not use a guide bushing if I were not plunging. I would happily use a template bit with a bearing if I did not want to plunge. I have plunged with fixed bases enough times to know that I do not want to do so in some circumstances.
Making a custom base plate is beginning to seem like the only practical option. I wonder if the power tool factory bases are made with enough variance to cause makers of after market parts to provide precisely fitting components.
I have made base plates in the past, but had hoped to find a product that provided both precision and ease of use while working with guide bushings.
Ben Dado is offline
post #19 of 24 (permalink) Old 09-11-2019, 11:31 AM Thread Starter
As a further follow up.
I purchased a Whiteside 3028 guide bushing. The bushing is sold with an accompanying dedicated centering pin so that you do not have to trust the "one size fits most" tapered cones that are offered for the purposes of centering. This appealed to me after I learned that two of the tapered deives which I tried were out of true.
Whiteside is the only manufacturer, which I have learned of, that produces accurate guides for use with their guide bushings. They make three sizes of guide bushing and each is supplied with a precisely manufactured matching centering pin.
I used the Whiteside 3028 to test the capability of the Jasper M 575B router base plate on my 1617EVS router in its RA 1166 plunger mount.
The photo I have attached is self explanatory.
I have not decided if I am going to return the Jasper M 575B, or if I am going to drill into the clear plastic base plate, shatter the material, and then wish I had returned it.
I would begin making my own custom base plate out of scrap wood this morning, but I have to shop for and purchase 2 or 3 properly sized Forstner bits to accomplish the task.
I am perplexed by the idea that there is not enough demand for a manufactured product that works well with the Bosch 1617 series to inspire a store bought supply to become available on the global market.
Ben Dado is offline
post #20 of 24 (permalink) Old 09-18-2019, 01:11 PM
I have an adapter plate for the PC bushing and really hate using it because the thread on the bushing is so short, and spring loaded that I find it almost impossible to secure it to the base. Maybe it's just me. I would prefer to use a brass bushing than the bayonet setup Bosch provides. I think I got a Rockler replacement base, but it was a long time ago. I prefer to use the fixed base for such cuts. Much of the time I can use a bearing guided bit instead of having to compute that offset of the bushing vs. the edge of the bit. IMHO.
