Enlarging a template by exactly the size of the cutter-bushing gap? - Page 2 - Router Forums
 3Likes
post #11 of 45 (permalink) Old 09-15-2019, 01:55 AM
Originally Posted by Inor View Post
Disclaimer: The following rant is mostly meant in humor, but there a few tidbits of truth to found as well. I leave it to you, the reader, to figure out which is which.
We are woodworkers! We don't DO metric! The English invented the Imperial System of measurement and they are still the best woodworkers in the world. Yeah I know, the Limeys caved in to the rest of the world and stupidly adopted the metric system years ago. If that bothers you, go punch a Limey. As for me, I would prefer to get them to teach me to properly sharpen Robert Sorby chisel.
Yes I agree, it is much easier to add and subtract numbers using the metric system. But division is a serious pain in the neck! What is half of 1/16 inch? Double the denominator and come up with the answer 1/32 inch. What is a third of 1/16 of inch? Triple the denominator and come up with 1/48 inch. Easy math to do in your head. I do a LOT of division when building stuff.
What is half of a millimeter? Now you have to switch number systems entirely. What is next smaller system from millimeter? - A penismeter? So half a millimeter is 5 penismeters? Dumb!
Complain all you want about the Imperial Measurement system, based on hexadecimal numbers, but it has served us pretty well. The computer, phone or tablet that you are typing on as you read this is also based on the same system.
Try reading through this thread and then get back to us Inor: https://www.routerforums.com/guide-b...surements.html
post #12 of 45 (permalink) Old 09-15-2019, 02:04 AM
Ashley the best way to see if a router bit will work at those 3 depths is to try one. 3/4 is only about 1mm smaller than 20 so it would give the same results. I think the 1/2" depth would be okay but I'm not sure about the deeper ones. If the bit can't clear the chips then they tend to run hot and the heat shortens the bit life. A US company that I know that makes a lot of metric sizes is Onsrud. You might try them and the bits are excellent quality.
post #13 of 45 (permalink) Old 09-15-2019, 02:10 AM
JOAT's Avatar
First Name: Theo
I'm having a major problem imagining what you are going to make. So I would need to know that, and see a picture of the pattern you say you have, before I could picture it in my mine. I'd likely have different ideas of how I would do it with that info. And if the holes are to be 1/2" deep I'd probably drill holes thru 1/2" material, then glue that to a solid piece of 1/2" material, or 1/4", 1/8", or whatever..
JOAT is offline
post #14 of 45 (permalink) Old 09-15-2019, 08:34 AM
Take a look at the Parf Guide - make the top any size that you need.
https://www.youtube.com/watch?reload=9&v=2DMtIiyfRXk
Ed3443 likes this.
tomp913 is offline
post #15 of 45 (permalink) Old 09-15-2019, 08:57 AM
First Name: Scott
https://imaginewoodworking.com/ sells a oversized 1-1/2 and 2" template guide bushing which makes using a 1/2" bit. Much easier math too.
scottgrove is offline
post #16 of 45 (permalink) Old 09-15-2019, 11:39 AM
TWheels's Avatar
@AshleyJ Can you possibly provide a drawing of what the final product will look like. A drawing one hole in the pattern will suffice. It seems to me there are simpler ways of achieving tour goal than what you propose.
I Want to Be the Person My Poodles Thought I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #17 of 45 (permalink) Old 09-15-2019, 03:03 PM
MEBCWD's Avatar
I'd used the original template and something like this https://www.toolstoday.com/flush-tri...l-bearing.html
MEBCWD is offline
post #18 of 45 (permalink) Old 09-15-2019, 04:49 PM
Country: South Africa
First Name: Biagio
Have you considered the Lee Valley dog hole bushings and bits (pg 270 of the Canadian catalogue download). They have 3/4” and 20 mm available.
Biagio is online now
post #19 of 45 (permalink) Old 09-16-2019, 12:26 AM
First Name: Gary
Here's a complete template, including the guide bushing. You can buy for 3/4" or for 20mm. It's designed for use with a Whiteside 1/2" upcut spiral bit. https://www.woodpeck.com/routing/rou...-jig-2019.html
It's pricey, but that's par for the course for Woodpeckers stuff. I have one of these for 20mm, but haven't tried it out yet. I bought it when I was between CNCs, but didn't get to the project I bought it for. I'm just finishing up my CNC, so will probably use it to cut my MFT-like cutting table (longer than an MFT). I also have the UJK Parf Guide System Tom mentioned. Both are very nice and will speed you on your way. Since you have a preference for using a router, the Woodpeckers system would probably be more to your liking. If you are interested in the UJK Parf Guide, get it here: https://tsoproducts.com/workholding-...-guide-system/ The shipping will kill you, if you order from UJK in England. Take a look at the cool stuff they have from UJK, and TSO's own products. Not a lot of products, but what they have is worth looking at. If you use a Festool track saw, their clamp on GRS-16 works remarkably well. I've used one for a couple of years or so. It's one of my go to accessories. Very accurate.
Gary
The Old Man and the C - - -NC
gmedwards is online now
post #20 of 45 (permalink) Old 09-16-2019, 12:57 AM
JOAT's Avatar
First Name: Theo
If that's what you all are talking about, be no biggie to make one. I don't like to buy what I can make, especially at Woodpecker's price.
JOAT is offline
