Guide Bushing Thread Size - Router Forums
 17Likes
post #1 of 15 (permalink) Old 01-06-2020, 04:27 PM Thread Starter
RickKr's Avatar
Default Guide Bushing Thread Size
I would like to know what the thread size is on the Porter Cable type guide bushings. It seems the OD may be nominally 1 3/16" but I've searched high and low, looked at a couple of the tutorials, googled it, etc., but nowhere have I found anything that says what the threads actually are, eg., 1 3/16" x 20 tpi.
These things are not spendy, but I'd have to order them as no local hardware store that I've gone to has them. I CAN make them and I have brass stock of appropriate size, that is, if I knew what the thread size is. I could make something up and just go with it, but it would be nice to make them compatible if possible.
Thanks,
Rick
"Quality is like buying oats. If you want nice, clean, fresh oats, you must pay a fair price. However, if you can be satisfied with oats that have already been through the horse, that comes a bit cheaper."
RickKr is offline
post #2 of 15 (permalink) Old 01-06-2020, 05:18 PM
PhilBa's Avatar
First Name: phil
The threads just need to match the retaining nut. If you're turning the threads, you could turn the nut, too. Definitely 1 3/16. The collar is 1 3/8, btw.
and, it looks like 20 TPI
MEBCWD likes this.
Visit my shop website.
PhilBa is offline
post #3 of 15 (permalink) Old 01-06-2020, 05:39 PM
one of these will tell you all you need to know...
post #4 of 15 (permalink) Old 01-06-2020, 07:25 PM
The sets aren't that expensive and they will deliver to your door. https://www.amazon.com/MLCS-9674-Bra...8360273&sr=8-5
roxanne562001 likes this.
post #5 of 15 (permalink) Old 01-06-2020, 08:26 PM Thread Starter
RickKr's Avatar
These things are not spendy, but [B]I'd have to order them as no local hardware store that I've gone to has them. I CAN make them and I have brass stock of appropriate size, that is, if I knew what the thread size is. I could make something up and just go with it, but it would be nice to make them compatible if possible.
Thanks,
Rick
...snip...
Not quite. I have those in both imperial and metric.
What I don't have, but need, is a guide bushing on which to use them on... Takes two to tango, no?
The sets aren't that expensive and they will deliver to your door....snip...
Certainly true, but it would take a minimum of three days to receive them. Once I have the information I need (which I now have), I can make a set in an hour or so.
Originally Posted by PhilBa View Post
...snip...
Yes, 20 tpi looks like it. That is all that I needed to know. Thanks.
Rick
Name:	Thread Size Guages 640.jpg
RickKr is offline
post #6 of 15 (permalink) Old 01-07-2020, 08:40 AM
sreilly's Avatar
First Name: Steve
Rick
Nice to have that ability and skill set.
sreilly is offline
post #7 of 15 (permalink) Old 01-07-2020, 09:47 AM Thread Starter
RickKr's Avatar
Yes, thanks, it is. It has served me very well over the years.
When I was in high school, in the early 1960s, my father, a tool and die maker/machinist, put me to work in his newly formed machining business: high precision, short-run production in exotic materials. Nuclear industry, deep sea camera housings, high-tech industries, in the San Diego, CA. area. I didn't like being forced to work at anything, but after a while, I came to realize the benefits of the skills I was learning and I found out it suited me. But, I became a professional fish biologist
For years, when I would visit my family, I'd bring a project to work on. Starting in 2000, I put together a small home shop in my basement and it has grown, mostly in my skills. I love to fix things, if I can repair or remake broken parts, etc. Now, in retirement, I like taking on projects for others. There are very few others in the small ranching valley where now live that have the skills and capabilities. I like to share it.
I have really been enjoying woodworking, which has really only been happening in earnest for a year. It provides all of the creativity challenges as working in metal, but it is easier and quicker in many ways. Wood is a lot of fun to work with. I now have a fair bit more diversity in the woodworking tools and machinery than I have for metal working.
This is a pretty friendly and helpful forum, which helps greatly, for a novice such as me.
Rick
harrysin, jw2170, billyjim and 2 others like this.
RickKr is offline
post #8 of 15 (permalink) Old 01-07-2020, 12:06 PM
First Name: Gary
Harbor Freight sells the PC style bushings pretty cheap.
gmercer_48083 is offline
post #9 of 15 (permalink) Old 01-08-2020, 08:51 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Whilst I do have a set of three piece Brass template guides, they are seldom used. For serious routing where large bits are used, not only is the depth of cut severely limited but if the chuck touches the Brass guide it can unscrew the guide ruining the project. Wherever possible I base projects on a 40mm (1.5" is close) because it solves both the above problems.
Harry
harrysin is offline
post #10 of 15 (permalink) Old 01-08-2020, 11:29 AM
First Name: Gary
Harry, I have had the same issue with the brass type nuts vibrating loose. I wrapped the threads with Teflon plumbers tape and that remedied that problem. It will not remedy the issue of the collet or a large bit though. It always seems like the answer to all these issues is to throw more $$$ at it. ( guides, templates, Jigs, assorted bits, bearings )
