I am a complete novice when it comes to using a router, well I have never used one, ever. The tool I use that most resembles a router is a dremel....
Well I need to replicate some parts for a boat, and I need them to be the pieces to be exact so I can laminate them with epoxy. I plan on purchasing the Crafstman black top router for $80 or the kit for $120 (the prices are closer to $65 and $100 right now with coupons). What I need to know is what bit do I use to duplicate 1/2" (well 15/32") frames into 1/2" plywood.
I looked at the "Home" stores and could only find bits designed to trim lminate, which did not look beefy enough for my application. I would also like the bit to remove as little wood as possible, marine ply is expensive and my nestings are tight to get all the pieces I need on as little wood as possible.
I am familar with power tools, I have done extensive work custom fiberglass/plywood composite projects, anything from custom car audio boxes to aquariums, precision is not such a concern when working with epoxy/fiberglass because the gaps create a better bond than two perfectly cut panels.
Thank you,
Nick
Thank you,
Nick
