Ryobi R163 guide bushing adapter plate - Page 2 - Router Forums
 5Likes
post #11 of 20 (permalink) Old 02-05-2018, 09:21 PM
Hi Jeff and welcome. There are two different sizes of bushings. The original PC style and these: 1-3/4" Brass Template Guides - Lee Valley Tools
Your router may be sized for the larger ones. I don't have a set so I can't say what the counterbore hole size should be.
post #12 of 20 (permalink) Old 02-06-2018, 09:39 AM
Honored Member
harrysin's Avatar
First Name: Harry
Originally Posted by JEFFSCABINETS View Post
I just did a google search for guide collars to fit Ryobi laminate trim routers and came across this forum. I can see I'll be spending a lot of time here.
Anyway, the lip hole in my router is almost 1 -9/16" and my PC collars are 1-3/8" so they fall through. I think I'll try getting some plexiglas type plastic and make a few new plates and with the help of a retired machinist friend see if he can make the right sized lip hole. I will keep some of those after market base plates as a back up plan idea.
This is my way.
jw2170 and TenGees like this.
Harry
harrysin is online now
post #13 of 20 (permalink) Old 02-13-2018, 02:34 AM
First Name: Jeff
Not sure what you guys mean by counterbore. I talked to my machinist friend today and showed him what I want. The Porter Cable collar and nut fall all the way through the base plate on the router I want it for. He's actually going to make the holes on a boring machine so they will be exact. Then all that needs to be done is do take a die grinder and burr and remove some plastic from the router base in the space where the collar nut will be. I need this set up to do mortising for door hinges. I don't want to pay a window and door shop to machine new doors to match old ones. I will make some templates from 1/2" MDF.
JEFFSCABINETS is offline
post #14 of 20 (permalink) Old 02-16-2018, 07:50 PM
TWheels's Avatar
@JEFFSCABINETS ,
I do hope these quick drawings explain how the CP (smaller) and Oak-Park/Lee valley template guides are attached to a router baseplate, and the terms counter bore and through bore.
Name:	template guide.png
I Want to Be the Person My Poodles Thought I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #15 of 20 (permalink) Old 03-25-2018, 11:00 PM
1fizgig's Avatar
First Name: Steve
Question
Originally Posted by lmikekelly View Post
Hello, I'm new at using routers. How do I adapt guide bushings to my Ryobi R163?
Hi there, is the Ryobi you have like this one:
Ryobi 1600W Plunge Router Product Detail - RYOBI Tools
I got a template guide with my one, but it's a fixed size piece of steel. I'm just thinking about whether or not I'll need some other guides at some point, so just looking to get a handle on what's available.
1fizgig is offline
post #16 of 20 (permalink) Old 03-26-2018, 09:34 AM
These are fairly standard sizes Steve: 1-3/16" Brass Template Guides - Lee Valley Tools This is the most common counterbore size but there are also 1 3/4". However, some routers are made for a adapter plate/bushing combination. I'm not familiar with that router to be sure what you have. On our home page are some good tutorials by Harry Sinclair that will explain how to use guide bushings effectively and why you need different sizes.
harrysin and 1fizgig like this.
post #17 of 20 (permalink) Old 03-27-2018, 11:16 PM
1fizgig's Avatar
First Name: Steve
Thanks Chuck, it's something in the back of my mind I know I'm going to need the further I get into this.
With my wife's penchant for dreaming up ideas, especially as she gets into her interior design course more and more, I suspect I'll be learning new ways to do a great many things.
1fizgig is offline
post #18 of 20 (permalink) Old 05-08-2018, 09:24 AM
First Name: Reuel
Default Get an adapter
You just need something like this
https://www.carbatec.com.au/joinery-...aptor-lgh-704r
reuelt is offline
post #19 of 20 (permalink) Old 09-26-2018, 12:11 PM
First Name: Jeff
I've been meaning to update my situation. I did some bartering with my machinist friend. I supplied some scrap 1/4" thick Plexiglas and he made a baseplate for my router. It will now accept Porter Cable guide collars. Sorry, not something you can buy in stores but it works great for applications where you don't need a big router.
TenGees likes this.
post #20 of 20 (permalink) Old 01-20-2019, 01:54 PM
I agree wholeheartly, just found I have this same router and same problem and same thoughts as to ... screw home depot and more so Ryobi. This is the rinky dink stuff that turns people off to ever repurchasing a particular product again. How dumb is that... spend all that money trying to get a customer just to lose because of stupidity.
scristaldi is offline
Guide bushing identification Mike Guide Bushings and Templates 42 09-22-2013 09:25 PM
Guide Bushing plate sakirfp Guide Bushings and Templates 7 11-27-2010 03:00 AM
Question about mounting a HF guide bushing adapter sofasurfer Guide Bushings and Templates 12 02-07-2010 03:35 PM
Guide Bushing Adapter scrollwolf Guide Bushings and Templates 4 09-17-2009 09:29 PM
Inlay Guide Bushing and base plate Doyle Portable Routing 3 06-07-2007 10:25 PM
