Ryobi R163 guide bushing adapter plate - Router Forums
 6Likes
post #1 of 24 (permalink) Old 04-17-2011, 10:57 PM Thread Starter
Default Ryobi R163 guide bushing adapter plate
Hello, I'm new at using routers. How do I adapt guide bushings to my Ryobi R163?
lmikekelly is offline
post #2 of 24 (permalink) Old 06-14-2011, 02:43 PM
First Name: Patrick
you cant. you have to get an adapter
pgadlin is offline
post #3 of 24 (permalink) Old 06-14-2011, 02:47 PM
First Name: Patrick
I got the same router at home depot the other day thinking I could use it with my rockler dovetail jig. Ryobi does not make a baseplate that will accomodate the bushings. You have to find a universal baseplate adapter. The one I got at Home Depot today was the Ridgid universal baseplate adapter that comes with the bushings. I will update when I use it tonight whether to return it or keep it. MLCS woodworking also has a baseplate replacement for the ryobi. the model number is 9339. this one supposedly replaces the base that is on there now and you can use bushings. That one is on order as well in case the ridgid doesnt work out..
It sucks that ryobi cant make their routers with a baseplate that you can put a guide bushing on so you wont jack up your jig templates. Oh well. There are alternatives..
Nickp likes this.
pgadlin is offline
post #4 of 24 (permalink) Old 06-14-2011, 06:00 PM
Here's a baseplate that will fit most anything and it comes with a set of guide bushings plus an adapter plate for any PC style bushing that may be a special size.
Amazon.com: Milescraft 1211 Base Plate Metal-Nose Bushing Set for Routers: Home Improvement
John Schaben
jschaben is offline
post #5 of 24 (permalink) Old 06-14-2011, 07:50 PM
dutchman 46's Avatar
First Name: Howard
There are other routers that have different bushings, and other differences. There are others that like theres a little different! If You make them all the same, the routers would have to agree to sell them all under one name! Some like Chevrolet's Some like Dodge, and still others believe that GMC are the one. Don't put them all in one room together! Mo one would come out whole.. :
John 3:16
dutchman 46 is offline
post #6 of 24 (permalink) Old 06-15-2011, 02:23 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
If you look at the Leigh website they do adaptor plates for most makes of routers that will enable the use of inexpensive PC type guide bushes.
See Leigh Industries - Joining Tradition With Today It is a less cumbersome solution to changing the baseplate which, as it is thicker, may introduce depthing problems.
Cheers
Peter
istracpsboss is offline
post #7 of 24 (permalink) Old 06-20-2011, 10:12 AM
First Name: Patrick
Default sucks for ryobi
After looking around on the web, at rockler, at harbor freight I came to the decision to return the ryobi and get the porter cable fixed base router that already has the baseplate on that will accept guide bushings.
pgadlin is offline
post #8 of 24 (permalink) Old 06-20-2011, 10:17 AM
Hi
Take a HARD look at the new Craftsman router for 1/2 the price of the PC,plus it comes with it all..and I mean with it all...
http://www.sears.com/shc/s/p_10153_1...6&blockType=G6
Sears: Online department store featuring appliances, tools, fitness equipment and more
post #9 of 24 (permalink) Old 09-05-2017, 02:39 PM
Default plunge router re180pl1
I need a guide bushing adapter to route letters
wnrjr is offline
post #10 of 24 (permalink) Old 02-05-2018, 06:07 PM
First Name: Jeff
I just did a google search for guide collars to fit Ryobi laminate trim routers and came across this forum. I can see I'll be spending a lot of time here.
Anyway, the lip hole in my router is almost 1 -9/16" and my PC collars are 1-3/8" so they fall through. I think I'll try getting some plexiglas type plastic and make a few new plates and with the help of a retired machinist friend see if he can make the right sized lip hole. I will keep some of those after market base plates as a back up plan idea.
JEFFSCABINETS is offline
Guide bushing identification Mike Guide Bushings and Templates 42 09-22-2013 08:25 PM
Guide Bushing plate sakirfp Guide Bushings and Templates 7 11-27-2010 02:00 AM
Question about mounting a HF guide bushing adapter sofasurfer Guide Bushings and Templates 12 02-07-2010 02:35 PM
Guide Bushing Adapter scrollwolf Guide Bushings and Templates 4 09-17-2009 08:29 PM
Inlay Guide Bushing and base plate Doyle Portable Routing 3 06-07-2007 09:25 PM
