router bushings - Router Forums
post #1 of 3 (permalink) Old 11-01-2011, 03:08 PM Thread Starter
Default router bushings
what size can i get router bushings--- and what material
3/8 out side and 5/16 inside
woodgage is offline
post #2 of 3 (permalink) Old 11-01-2011, 03:16 PM
9 Piece Router Template Guide Set
post #3 of 3 (permalink) Old 11-01-2011, 04:14 PM
Wow, 3/8 OD and 5/16 ID doesn't give you much wall thickness, like 1/32. Mine (4 sets) are all 9/32 or so ID. What are you doing? Better description of the task may be able to generate some alternatives for you.
John Schaben
jschaben is offline
router base and bushings sunny brae General Routing 0 03-23-2011 04:55 PM
Guide Bushings for Triton Router Sliderule Guide Bushings and Templates 8 03-30-2010 10:18 PM
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 04:43 AM
