Making templates based on designs done on the computer - Router Forums
post #1 of 4 (permalink) Old 11-03-2011, 09:35 PM Thread Starter
First Name: Fred
Default Making templates based on designs done on the computer
I just purchased a bowl and tray bit for my router and am anxious to make all sorts of different designs. Eagle America sells a slew of templates, but at $25-30 each they are somewhat pricey. I was thinking I could make my own but the process has not gone well so far.
I used a drawing program on the computer to draw the templates, then I printed out and used spray adhesive to attach to MDF, then I jigsawed and sanded up to the lines, but the problem is that it seems very difficult to get perfectly straight lines, or to avoid creating flat spots when sanding around corners.
I am sure that the commercial guys probably use some sort of CNC process to create their templates, but I was wondering if anyone had any suggestions on how one could do it themselves cost effectively. I assume that a CNC shop would probably be happy to do it for me but at a cost that would probably be 20 times what it would have cost to buy the template in the first place.
I know I could go the route of using a straight piece of something coupled with a pattern bit to route straight lines, and I could cut circles and do the same thing to cut curves, but that seems like a lot of work.
Not trying to sound like I want something for nothing, but I thought maybe there is a simpler solution that I am not seeing. Any advice?
Vrtigo1 is offline
post #2 of 4 (permalink) Old 11-04-2011, 12:47 PM
RJM60's Avatar
First Name: Robert
If you already had something that you wanted to use to create a bowl shape (plastic decoration, wooden puzzle, serving dish), you might be able to use a pattern bit to transfer the shape to a piece of MDF, which would become a "master" template that you could use to transfer the shape to yet another piece of MDF. You could try perusing some Goodwill stores for odds and ends that might make interesting shaped bowls.
With careful selection of guide bushings and bit diameters, you could use the "master" to transfer larger, or smaller, versions to a second piece of MDF, which would become the actual template used for your bowl. You should first make several MDF blanks that are all the same size and have square corners (i.e. the corners are all 90°). This would make it easy to line up templates if you need to (like if you need 2 templates to make one bowl). Also, having MDF blanks the same size will permit use of holders like the ones many members have made.
For many of these decorative templates (e.g. Christmas tree tray), it doesn't really matter if you get the exact shape that you created on the computer. As long as the template looks good, it will make a nice bowl. It might require additional sanding, cutting, or even starting over but once you have the template, you have it forever 9and you can make copies of it too). One thing to remember is that when 2 inside straight sides (edges) meet, the corner will be the diameter of the router bit. This means that you don't have to make inside corners on your templates unless you want the corner radius to be larger than your router bit.
All that said, you will have to decide if you want to spend time making jigs and fixtures, or making bowls (i.e. by buying the template). I'd suggest buying a simple one first, then make a few bowls so you see how everything works together, then if you want to make your own templates after that, you'll have a better understanding of what would be required to make the template work.
I hope all this is understandable. If not, I can try to clarify, along with many others on this forum. If possible, post some pictures of what you end up making (including templates).
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #3 of 4 (permalink) Old 11-08-2011, 10:01 AM Thread Starter
First Name: Fred
Thanks for the suggestions, the fact that I don't need to make rounded corners on the jig was lost on me, but now that I see it in writing it makes perfect sense. Thanks!
Vrtigo1 is offline
post #4 of 4 (permalink) Old 11-08-2011, 11:55 AM
RJM60's Avatar
First Name: Robert
Correction, or clarification, for what I wrote below.
If you're using a guide bushing with an internal template (i.e. cutting around the outside of a template to make the inside edges of your project), if the template has sharp (outside) corners, rotating the router around the corner will result in a radius equal to the offset.
The offset is equal to 1/2 the guide bushing diameter less 1/2 the bit diameter.
If you don't want the outside corner to be radiused, you have to stop your cut when the center of the bit is even with the corner.
Note that if you're using a pattern bit (bit with a bearing on top), since the bearing is the same size as the bit, the offset is zero and you will get sharp outside corners.
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
Sign Making Router Bits and Letter Templates Auggie General Routing 4 04-20-2016 06:37 PM
Need help making inserts for templates patmine Guide Bushings and Templates 4 03-27-2011 12:44 PM
help with making templates JTN89 Jigs and Fixtures 4 03-23-2009 12:53 AM
What tips can you share about making templates for collar guided routing? paulcomi Jigs and Fixtures 6 01-27-2006 02:33 AM
Making your own dovetail jig templates Dominick Giarraputo Jigs and Fixtures 2 09-03-2005 06:17 AM
