guide bushings - Router Forums
post #1 of 4 (permalink) Old 11-05-2011, 11:01 AM Thread Starter
Default guide bushings
I am about to purchase my first set of router guide bushings, what should I be aware of ?
dart5245 is offline
post #2 of 4 (permalink) Old 11-05-2011, 11:11 AM
Welcome.
Make sure they fit your router base. The PC style (1-3/16") is the most common.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 4 (permalink) Old 11-06-2011, 05:43 AM
dutchman 46's Avatar
First Name: Howard
Welcome n/a! One thing I found out about is, The Harbor Freight collars are a great fit, and finish. I got some last year, and for $12.00 and some change, I had a great set from Them! You can save a bit of money there
John 3:16
dutchman 46 is offline
post #4 of 4 (permalink) Old 11-06-2011, 06:00 AM
HI
They are NOT all made the same way,some have fine threads that said buy two sets so you can cut off the some of the stems to 1/4" long plus some of the sets come with a 1" guide and some don't you want to get the set with the 1" one in the set..
You may say why would I want to cut off some, most of your templates will be 1/4" thick or to say they should be and the longer guides will drag on the bottom of the stems, it's true you can buy the short stem type but at about 40.oo per set the norm..
If you can swing it get 3 sets you can't have two many and all with the same thread on them..
9 Piece Router Template Guide Set
http://www.routerforums.com/jigs-fix...ss-guides.html
Using guide bushings with your router Mike Guide Bushings and Templates 15 12-04-2013 12:32 PM
Base plates that recieve guide bushings TanOak Table-mounted Routing 10 10-15-2011 09:55 AM
Harbor Freight Guide Bushings Work Better. RJM60 Guide Bushings and Templates 0 08-02-2010 05:06 PM
Help! Rockler Std. Guide Bushings? Richard44 General Routing 3 06-20-2009 01:12 PM
need something to use guide bushings on! Help Please!! unlimitedwoodworker Guide Bushings and Templates 8 11-15-2007 03:42 PM
