Makita RP2301FCX what guide bushings are compatible - Router Forums
post #1 of 10 (permalink) Old 11-17-2011, 01:12 PM Thread Starter
TheOakDude's Avatar
First Name: Paul
Default Makita RP2301FCX what guide bushings are compatible
Hi everyone,
Wondering if there are any known other makes of guide bushes which are compatible with makita, apparently makita 3612 is same as far as guide bushes go.
Or do have to buy only Makita bushes??
any suggestions or guidance will be greatly appreciated.
thanks
TheOakDude is offline
post #2 of 10 (permalink) Old 11-17-2011, 04:48 PM
pal
pal's Avatar
First Name: Harold
Get a set like this the adapter ring fits into your existing base. 10 PC BRASS TEMPLATE GUIDE SET - ROUTER CUTTER BITS | eBay
Regards Harold
Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning.
Albert Einstein
pal is offline
post #3 of 10 (permalink) Old 11-17-2011, 04:57 PM
dutchman 46's Avatar
First Name: Howard
I got a set from Harbor freight, and they are great ! They cost Me about $10.00 ! You can call Them and They also have a black Friday, I believe. There are some things that are good fit, and the money is great.
John 3:16
dutchman 46 is offline
post #4 of 10 (permalink) Old 11-19-2011, 12:09 PM
Paul, for most members I would suggest using brass guide bushings but for those with Makita routers I think Makita guide bushings are the way to go. On the older models the guide bushing was attached with two screws. Your new router uses a toolless device, a lever that releases the bushing. Older bushings with the attaching holes will work fine with this set up. Makita offers a wide selection of sizes in both SAE and metric.
post #5 of 10 (permalink) Old 11-19-2011, 12:17 PM
Hi
Just my 2 cents, the plate will work on all routers..and you get the guides in the deal..
Amazon.com: Milescraft 1201 Base Plate / Bushing Set for Routers: Home Improvement
post #6 of 10 (permalink) Old 11-19-2011, 05:21 PM
pal
pal's Avatar
First Name: Harold
With the milescraft turnlock base plate you can only line up 2 screw holes and to take the base plate off the Makita is a real pain what with the 2 springs and the lever and a bigger pain refitting it, that said you could just get a couple of longer screws and fit the milescraft plate over the existing plate which is what I do. I suggested the brass guides as the Makita template guides range in price from $14.45 Au for 1 up to $31.25 Au. per guide In the UK at Axminister they range in price from 10.36 Bp to 15.30 Bp per guide.
I use the Milescraft turnlock base plate and guides, also the brass guides and the Makita guides on the RP2301FC.
You can just make out the 2 lugs that hold the adapter ring in. They are just below the 2 screws.
Regards
Harold
Name:	Brass Guide .JPG
Albert Einstein
pal is offline
post #7 of 10 (permalink) Old 11-20-2011, 06:33 AM Thread Starter
TheOakDude's Avatar
First Name: Paul
Harold,
where can I get these brass guides which fit my Makita RP2301FC.
thanks
post #8 of 10 (permalink) Old 11-20-2011, 09:06 AM
MLCS and Woodcraft both ship overseas.
post #9 of 10 (permalink) Old 11-20-2011, 11:13 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Paul
Axminster do the Leigh metal adaptor plates that enable the use of the cheap brass guides for most makes of router. They are not dear and are the most elegant solution I've come across.
Cheers
Peter
istracpsboss is offline
post #10 of 10 (permalink) Old 11-20-2011, 02:40 PM
pal
pal's Avatar
First Name: Harold
Hi Paul ebay in the uk have them.brass guides | eBay
Regards
Harold
Albert Einstein
pal is offline
Base plates that recieve guide bushings TanOak Table-mounted Routing 10 10-15-2011 09:55 AM
Harbor Freight Guide Bushings Work Better. RJM60 Guide Bushings and Templates 0 08-02-2010 05:06 PM
Can i use a makita router with a makita template guide with a porter cable jig? oshinobi Jigs and Fixtures 2 06-17-2009 12:24 AM
need something to use guide bushings on! Help Please!! unlimitedwoodworker Guide Bushings and Templates 8 11-15-2007 03:42 PM
