Guide bushings - Router Forums
post #1 of 4 (permalink) Old 11-21-2011, 10:00 AM Thread Starter
First Name: Keith
Default Guide bushings
After the advice from here I went ahead and bought a set of the universal guide bushings in brass, I new they wouldn't fit my Erbauer router but hoped they might well fit the cheap Black & Decker KW850, the answer is, Almost, the adapter plate is a millimetre or so too small to fit directly to the router base, I take it that now my only way round the problem is to make new base plates for both routers that will accept the silverline universal adapter ring and guide bushings ? or is there another universal kit that has an adapter to fit either the B&D or Erbauer routers ?
Tazkb is offline
post #2 of 4 (permalink) Old 11-21-2011, 11:21 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Keith
Check with Axminster for those Leigh adaptors. One or other of them should fit the Erbauer.
Cheers
Peter
istracpsboss is offline
post #3 of 4 (permalink) Old 11-22-2011, 09:26 AM Thread Starter
First Name: Keith
Hi Peter had a look on the Axminster web site but can't find them adaptors to fit the Erbauer ? do you have a link Peter ?
thanks
Tazkb is offline
post #4 of 4 (permalink) Old 11-22-2011, 11:31 AM
Keith, You can easily build your own sub base plates for using guide bushings. There is a sticky thread in this section about it and a video with similar photos and instructions will be online very soon.
Using guide bushings with your router Mike Guide Bushings and Templates 15 12-04-2013 01:32 PM
Base plates that recieve guide bushings TanOak Table-mounted Routing 10 10-15-2011 10:55 AM
Harbor Freight Guide Bushings Work Better. RJM60 Guide Bushings and Templates 0 08-02-2010 06:06 PM
matching Bosch router to PD guide bushings. drtimdc Guide Bushings and Templates 5 01-03-2010 07:18 AM
need something to use guide bushings on! Help Please!! unlimitedwoodworker Guide Bushings and Templates 8 11-15-2007 04:42 PM
