I have an Idea ! - Router Forums
post #1 of 29 (permalink) Old 11-27-2011, 10:53 AM Thread Starter
First Name: Keith
Default I have an Idea !
it occured to me last night while in the workshop as i was marking out some new sub bases on some acrylic that it would be easier to make an adapter ? i.e. as I have a router that's difficult to get guide bush's for I have started to make some new sub bases, but with the router came one 30mm bush, it would easier to use this bush to make an adapter plate by copying the 30mm guide bush but making the center fit the pc style box of bushes i have bought ? has anyone else gone down this route ?
thanks
keith
Tazkb is offline
post #2 of 29 (permalink) Old 11-27-2011, 11:55 AM
thanks
keith
Sure, but you could probably save yourself some trouble for 12 pounds.
Milescraft 1251 Base Plate / Bushing Set for Routers - EXCLUSIVE SALE PRICE!!: Amazon.co.uk: DIY & Tools
The kit includes an adapter for PC style bushes
John Schaben
jschaben is offline
post #3 of 29 (permalink) Old 11-28-2011, 09:54 AM Thread Starter
First Name: Keith
bearing in mind i hate those bases, so full of bloody holes unless your stock is perfectly smooth they catch things and get moved about, just my opinion mate
and also I doubt with my luck that it will fit the Erbauer router anyway ? Plus I have already bought a set of bushes pc style ones so buying another set seems
a bit pointless
Tazkb is offline
post #4 of 29 (permalink) Old 11-28-2011, 10:32 AM
Hi Keith
The bloody holes holes will NOT hang up the router, if you can't find a set of holes to fit your bloody router I'm sure if not you can drill one or two so it will fit ,you just need two screws to hold it to the router, you can use your bloody guides with it and a real plus you can use up to a 2" OD bit without switching the base plate out, try that with a PC type plate that can only take on the PC type guides, plus the bloody base plate is 7" OD to help your bloody router stay flat on your the timber.. one BIG plus you can pop in the brass guide easy and get the ring nut tight and then put in back in place with just a 1/4 turn..
You can't have to many guides
a bit pointless
post #5 of 29 (permalink) Old 11-28-2011, 10:39 PM
wcpalmer's Avatar
Send a message via Yahoo to wcpalmer
Hi Keith,
I agree with Bob. I have 4 of those bases mounted on 3 craftsman router and a Bosch router. I have never had a hang up problem with them. The Milescraft base makes changing set ups very convenient.
Bill
wcpalmer is offline
post #6 of 29 (permalink) Old 11-29-2011, 04:42 AM Thread Starter
First Name: Keith
ok you got me i'll try one as they are on offer, shhhss anything for a quiet life, whats with all the bloodies ? have you cut yourself BOB ? I only used the expletive once mate, no need to go overboard, or maybe it's a miss understanding American Humor ? happens a lot with my American buddy over here.
Tazkb is offline
post #7 of 29 (permalink) Old 11-29-2011, 04:44 AM Thread Starter
First Name: Keith
right i have one on it's way, happy now guys ?
if it's crap you know i'll be blaming you don't you
Tazkb is offline
post #8 of 29 (permalink) Old 11-29-2011, 11:34 AM
Ken Bee's Avatar
First Name: Ken
Probably yourself for not using stock that is not smooth enough to prevent catches. If you are really worried about the holes catching why don't you chamfer the edges very slightly with a handheld countersink. That way you will have no bloody worries.
When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong.
Ken Bee is offline
post #9 of 29 (permalink) Old 11-29-2011, 12:09 PM
HI
Blame bloody John
post #10 of 29 (permalink) Old 11-29-2011, 05:14 PM Thread Starter
First Name: Keith
ok Bob the bloody everything is wearing thin mate, it was only a joke mate.
when it comes I might well use it on the other router as i have an idea it might well be a better fit, I'm just waiting for some jig parts comming then I can get on with the slot mortiser I have made, then I will make some stock of loose tenon material and i'll be ready to do the bed for my son, I really wan't to have a play with a pantograph, just not sure i have enough patience, we will see
Tazkb is offline
A dangerous idea? matt1710 Table-mounted Routing 7 02-27-2011 04:37 AM
A crazy idea? matt1710 Table-mounted Routing 15 10-03-2010 01:41 PM
Making puzzles, looking for a jig idea kweinert Jigs and Fixtures 3 08-31-2009 08:59 AM
New Forum Organization Idea Mark Site Help and Suggestions 55 11-11-2008 01:57 PM
