Bosch 1617 template guide - Router Forums
post #1 of 10 (permalink) Old 12-02-2011, 12:48 AM Thread Starter
First Name: Owen
Default Bosch 1617 template guide
Hi,
I am looking for a template guide for a Bosch RA1160 base. Where, O where can I find one?
oodges is offline
post #2 of 10 (permalink) Old 12-02-2011, 12:50 AM
papawd's Avatar
First Name: warren
Welcome Owen, I would start with Google searches and say good luck
papawd is offline
post #3 of 10 (permalink) Old 12-02-2011, 04:31 AM
xplorx4's Avatar
First Name: Jerry
Greetings Owen and welcome to the router forums, we are glad to have you join us.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 10 (permalink) Old 12-02-2011, 11:31 AM
Honored Member
First Name: pat
Dime a dozen at Bosch, see their front page for sources
or change plates for PC/DW apps.
Quillman is offline
post #5 of 10 (permalink) Old 12-02-2011, 11:37 AM
Amazon.com: Bosch RA1125 7-Piece Router Template Guide Set: Home Improvement
Originally Posted by oodges View Post
Hi,
post #6 of 10 (permalink) Old 12-08-2011, 07:56 AM
bob14's Avatar
First Name: Bob
Just ordered the set from Amazon myself ...2 day delivery!!
The set is about the same price as a couple of bushings at Woodworkers supply.
Now if I just knew how to efficiently use them .....
bob14 is offline
post #7 of 10 (permalink) Old 12-08-2011, 11:59 AM
Cassandra's Avatar
First Name: Cassandra
Hi Owen:
The route I took was the following:
Lee Valley Adapter Base Adapter Base Plate - Lee Valley Tools
with
Porter-Cable-style bushings 1-3/16" Brass Template Guides - Lee Valley Tools
As Bob has indicated in other threads, it's easy to make your own base-plates. This is something I am doing at the present time, as the Lee Valley Tools Adapter Base, being just a little larger diameter than the router base, doesn't meet all my needs.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #8 of 10 (permalink) Old 12-08-2011, 12:34 PM
Owen, the Bosch quick change adapter is a pleasure to use; just a quick flip of the spring loaded lever and you pull your bushing or adapter and two piece bushing from the router. Bosch steel guide bushings are best used for rough construction. For other work I prefer using the adaptor with PC style guide bushings or an Oak Park 7" square base plate with the larger diameter Oak Park/Lee Valley style guide bushings.(This allows for more variations on bit/bushing ratios) Bosch service centers have both the adapters and steel bushings in stock. You can also buy at Amazon or for a more personal approach I like the friendly people at Marsh Power Tools. I recently bought the new MRC23evsk from them and they gave me the adaptor at no charge!
post #9 of 10 (permalink) Old 12-14-2011, 12:28 AM Thread Starter
First Name: Owen
Thank you so much for all the replies.
oodges is offline
post #10 of 10 (permalink) Old 12-14-2011, 07:13 AM
Honored Member
harrysin's Avatar
First Name: Harry
My series of tutorials for beginners may be a good starting point Owen, here is the link:
Router Forums - View Single Post - A series of routing tutorials for beginners
Harry
harrysin is online now
Bosch 1617 screw hole template bigroccrek Table-mounted Routing 6 09-04-2016 12:30 PM
Porter Cable 55160 Omnijig Review Echonav Tool Reviews 19 06-21-2015 03:59 AM
Bosch 1617 EVS router guide bushing advice Mark Mayo General Routing 4 01-31-2011 12:41 PM
Guide bushing set for Bosch 1617 sofasurfer General Routing 8 02-05-2010 01:34 PM
Which template guide bushings do I need for Bosch? sofasurfer General Routing 6 01-31-2010 10:30 PM
