Small bits and templates - Router Forums
post #1 of 4 (permalink) Old 01-27-2012, 11:48 PM Thread Starter
Default Small bits and templates
Hi,
I'm planning to route some letters into wooden blocks that have been veneered as a toy block collection. I'd like fairly crisp corners on the letters if possible, and am searching for a small bit and a tight template guide bushing. Also looking for lettering templates or (better) a place that could make lettering templates from fonts. I had considered using a dremel, but I think I'm leaning towards my bosch colt laminate trim router instead.
Any thoughts on where I could get fine bits and template bushings to match?
Chris
cab938 is offline
post #2 of 4 (permalink) Old 01-27-2012, 11:54 PM Thread Starter
And just to clarify, the tightest template bushing I can see out there is 5/16" OD. Is there anything that would get me smaller? Stewmac has bits that go smaller, but I need a template bushing to use with them...
cab938 is offline
post #3 of 4 (permalink) Old 02-03-2012, 03:53 PM
ggom20's Avatar
Country: France
First Name: Gerard
hello!
Thinking about pantograph intead of templates..
regards
ggom20 is offline
post #4 of 4 (permalink) Old 02-04-2012, 06:59 AM
CharleyL's Avatar
First Name: Charley
When I did this I cut my letters from thin stock using a scroll saw, then glued them into a routed recess in the blocks that was the same depth as the letter stock. A small fixture to hold block with a template that fit over the block allowed routing out this recess using a small mortising bit and a guide bushing.
Charley
CharleyL is offline
Sign Making Router Bits and Letter Templates Auggie General Routing 4 04-20-2016 06:37 PM
For Sale: Misc Router Inlay Templates dovetail_65 Woodworking Classifieds 3 02-21-2011 11:55 AM
using templates and bits with bearings Ean Table-mounted Routing 2 05-24-2010 07:51 AM
using 1/8 straight bits for templates rout1111 Guide Bushings and Templates 1 07-02-2009 11:49 PM
Router bits for templates asrubin Router Bits - Types and Usage 1 01-29-2008 04:35 PM
