Trend router carver templates wanted - Router Forums
post #1 of 17 (permalink) Old 02-10-2012, 09:55 AM Thread Starter
First Name: malcolm
Default Trend router carver templates wanted
Hi there, im looking for trend RC templates, can anyone help please? as i have just discovered these are now discontinued. I'm looking to collect a few of these. Fair price paid
Malcolm12 is offline
post #2 of 17 (permalink) Old 02-10-2012, 10:06 AM
RC templates = ???
post #3 of 17 (permalink) Old 02-10-2012, 02:49 PM
MEBCWD's Avatar
Hi Malcolm,
Welcome to the Router Forums
I think the templates you are looking for are way over priced. All of their templates have been used over and over by many people and you will see the same designs time and time again.
You have a router so make the templates yourself. All you have to do is a little math and you can make unique designs that only you have. It would be fun and you can learn a lot about using bushings while you are making them.
Start with your design and add the offset dimension from outside of the bushing to the bit. This will give you the cutout for the template. then just cut out the hole and use the bushing and bit you designed the template with to cut your design over and over again.
Hope this helps,
MEBCWD is offline
post #4 of 17 (permalink) Old 02-10-2012, 03:21 PM
I still don't know what RC templates are ??
How about a link or a picture ?
Originally Posted by MEBCWD View Post
Hi Malcolm,
Hope this helps,
post #5 of 17 (permalink) Old 02-10-2012, 03:37 PM
MEBCWD's Avatar
Trend had a set of templates they called "Trend Router Carver Templates"
They are too expensive as far as I'm concerned.
Cheap Router Carver Templates, Buy Router Carver Templates Online at DIY Tools
MEBCWD is offline
post #6 of 17 (permalink) Old 02-10-2012, 05:04 PM
Gene Howe's Avatar
First Name: Gene
WOW!
Those are high, aren't they?
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #7 of 17 (permalink) Old 02-10-2012, 06:09 PM
Hi Mike
Thanks, I have the full set of the CMT type, it's almost impossible to make your own unless you have a CNC machine and a good one at that. the key to the system is the router bit and it's not cheap.
150.oo each if I recall ,but I do have 3 of them and I keep them in a very.spec.place in the cabinet..
CMT 3D Router Carver System - Woodcraft.com
CMT 3D Router Carver System Presented by Woodcraft - YouTube
http://www.routerforums.com/cnc-rout...r-carving.html
http://routerbitworld.com/3D-Router-...stem-s/932.htm
post #8 of 17 (permalink) Old 02-10-2012, 07:57 PM
Also available in Australia:
CARB-I-TOOL
Sydney, Australia
jw2170 is offline
post #9 of 17 (permalink) Old 02-10-2012, 09:04 PM
Thanks James
What's the price down under ?
CARB-I-TOOL
post #10 of 17 (permalink) Old 02-10-2012, 09:59 PM
MEBCWD's Avatar
James evidently the system was invented in Australia from what the video says.
Bob it looks like to me that the whole system is built around that expensive bit. The bit with cone shaped bushing gives it the ability to give the routing a hand carved look. The templates are still flat templates with holes cut into them. They would be a little harder to design than I siad because you need to take into account that your bushing is not one size but has a variable diameter as it goes up and down following the template.
Taking this into account you should still be able to make templates of your own. You use the same hole over and over to get a symmetrical design just like a Milescraft Inlay/Design Kit.
A lot of trouble ... yes. A lot of fun ... yes. If it works ,,,, a great felling of accomplishment.
I have faith in you Bob, you can do it, I know you can!!
Work Safe, Have Fun, Cut Some Wood,
MEBCWD is offline
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Advice Wanted on making a router table merlysys Table-mounted Routing 1 08-12-2011 12:44 PM
Router forums tall tails reible Lobby 11 03-03-2008 11:22 AM
