New to guide bushings - Router Forums
post #1 of 4 (permalink) Old 02-12-2012, 08:08 AM Thread Starter
First Name: Bob
Default New to guide bushings
I am working on a project requiring guide bushings, which I haven't used. How much clearance is necessary between the bit and the bushing?
I tried a 1/4" bit in a 3/8" bushing in my Porter Cable to route a curved track. The clearance must have been too small, because it looks like the bit managed to loosen the bushing, and the inner bushing ring subsequently loosened the collet holding the bit. Basically, the bit loosened, my groove deepened, and the piece split.
So I'm assuming the necessary clearance is more than I allowed. Are there any guidelines?
thebergs1 is offline
post #2 of 4 (permalink) Old 02-12-2012, 08:46 AM
Hi Bob
1/16" is good as a mile with a router, but the bit and guide must be setup on dead center on the base plate but here's little spring washer you can add on to keep the ring in it's place.
Router Bushing Spring Washer
Router Accessories
MLCS Router Accessories Page 2
" Sometimes, template guide bushings vibrate loose during a cut.... it's frustrating and can cause costly errors in your work or even destroy your bushings.
Now, STOP that problem for good with this new spring washer.
Just the right amount of pressure on the locking nut keeps the bushing perfectly secure. 1-3/16" OD washer, pack of 2."
2 Piece Bushing Spring/Lock Washers Set
#9044 ..........................SALE! $5.95"
Just a note
It's sometimes hard to get your fingers in that small spot to get the right nut tight, the tool below will make it easy,you can find them at just about any auto store for a song..
http://www.amazon.com/Lisle-52990-Sp...9060621&sr=1-1
plus if you use the bigger guides (1 1/2") you can get the spring washers for them from carr-lane....
http://www.mcmaster.com/#disc-springs/=g81hwl
http://www.routerforums.com/guide-bu...ss-guides.html
Name:	spring washer.jpg
Name:	wire puller.jpg
post #3 of 4 (permalink) Old 02-12-2012, 11:03 AM
Gene Howe's Avatar
First Name: Gene
Bob,
The spring washers are a good idea.
I've always used Teflon plumber's tape.
The washers would be less hassle, I think.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 4 (permalink) Old 02-12-2012, 02:36 PM
Hi Gene
" Teflon tape " = me too at one time but I always got it on backwards and it would come off when I put the ring nut in place, not the sharpest pencil in the box sometimes I guess
So I said I need something that I could do easy I can drop a washer on without using my head.. LOL
Originally Posted by Gene Howe View Post
Bob,
Using guide bushings with your router Mike Guide Bushings and Templates 15 12-04-2013 12:32 PM
Base plates that recieve guide bushings TanOak Table-mounted Routing 10 10-15-2011 09:55 AM
Harbor Freight Guide Bushings Work Better. RJM60 Guide Bushings and Templates 0 08-02-2010 05:06 PM
routers levon Table-mounted Routing 18 10-03-2008 09:11 PM
need something to use guide bushings on! Help Please!! unlimitedwoodworker Guide Bushings and Templates 8 11-15-2007 03:42 PM
