Template Guide? - Router Forums
post #1 of 7 (permalink) Old 02-19-2012, 09:51 AM Thread Starter
Default Template Guide?
Hello,
I'm really new to the guides and templates of routing.
I have a project where I need to rout 4 holes 1/4" by1"
in four corners on a top. I searches the forum and didn't quite see what I needed.
Any help would be greatly appreciated
Thank You,
Jim
James R is offline
post #2 of 7 (permalink) Old 02-20-2012, 12:40 PM
RJM60's Avatar
First Name: Robert
Originally Posted by James R View Post
Hello,
Thank You,
Jim
I'm assuming you want to make 4 slots 1/4" wide and 1" long near the edges of a board. An edge guide should work. You might also want to use stop blocks. You could use a template as well. I'd suggest you do some googling on youtube and buy a book about basic router techniques.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #3 of 7 (permalink) Old 02-20-2012, 06:38 PM Thread Starter
Thanks, i got the book but just wasn't understanding how to do what I need to do.
Which is 4 circles in a board 1.5inch dia by 1/4 inch deep. These are rubber feet holders
for speaker cabinets to enable stacking without sliding.
James R is offline
post #4 of 7 (permalink) Old 02-20-2012, 08:50 PM
The easiest way would be with a 1.5" Forstner drill bit. Much simpler than a router and much faster. The Forstner bit has a spur point so that if you measure your spots and use an awl to make a starting hole to locate the bit it will be more than accurste enough. You can make a scratch on the side of the bit with the awl once you have the depth you want so that you can get all the depths the same. That's if you are drilling by hand. Setting the depth on a drill press makes it much simpler.
post #5 of 7 (permalink) Old 02-20-2012, 09:46 PM
Hi James - I'll second Chucks suggestion that the forstner bit would be much simplier, easier and faster. However, if you really want to use a router you would need a template with a hole in it the size of the circle you want (1.5") plus the difference between the diameter of the bit you want to use minus the diameter of the bushing you want to use. In other words if you want to use a 1/2" bit with a 3/4" bushing, the template would need a 1.75" diameter hole (1.5" + (.75" -.5") = 1.75"). Then you would need to deal with the issue of exactly centering it over where you want the hole. Now, if you have a lot of these boards to do, a template the exact size of the board with the guide holes positioned properly would work well for you. If you have a drill press, stop blocks could also be set to make that a quick job... lots a ways to skin a cat..
John Schaben
jschaben is offline
post #6 of 7 (permalink) Old 02-21-2012, 06:16 AM
Bargains Finder
First Name: Tommy
Sears has this varijig on clearance right now for 1/3 the usual asking price, a good buy for what your looking for , Sears: Online department store featuring appliances, tools, fitness equipment and more
Tommyt654 is offline
post #7 of 7 (permalink) Old 02-25-2012, 10:39 AM Thread Starter
Thank you, I got the Forstner bits, and I'll make up a jig as I have 8 cabinets to do.
Than you,
James R is offline
Porter Cable 55160 Omnijig Review Echonav Tool Reviews 19 06-21-2015 03:59 AM
Hitachi Template Guide Installation mtgilbert Guide Bushings and Templates 20 08-02-2009 07:09 AM
proxxon template guide? miserybob Guide Bushings and Templates 3 07-08-2009 05:43 PM
Harbor Freight 10 piece template guide set rstermer Tool Reviews 4 06-29-2009 07:29 AM
Workout the offset for a template guide opelblues Guide Bushings and Templates 5 04-29-2009 12:44 PM
