Learning about using templates. - Router Forums
post #1 of 16 (permalink) Old 03-19-2012, 07:53 AM Thread Starter
First Name: Johnny
Default Learning about using templates.
Iíve been using my routers pretty much all weekend and my Porter Cable 890 router with the plunger attachment gave me a rough time of trying to follow around the inside my guides because of all stuff extending outside the base, not to mention the huge size of it. If it wasnít for the ĹĒ shank I would have just used my trim router for everything.
So I started looking at YouTube videos of routing jigs and saw for the very first time how the top bearing bits worked, OMG if I only had known this 20 years ago I might have actually used my routers more. In fact the stuff I made this weekend could have been so much better and taken half the time if I had one of the bits. Basic Router Jigs with Ron Fox Part 1 - YouTube
Then I remembered that I just bought a new bushing set that I could have also used had I thought about it. I havenít even opened up the package yet and Iím not even sure how to connect it up to the router. I tried using bushings 20 years ago and didnít have the right set up, for one I didnít like that the bushing was larger than the bit and I had to compensate for the difference. It wasnít a big deal and I still had to that for using the base as a guide except I made a lot of mistakes when switching to different sizes. And also my bushing didnít quite fit the craftsman router and would fall out, so I gave up on it all together.
So today Iím going to pull out the bushing set that I just bought and try to get it working. But I was wondering should I just buy the top bearing bit and forget about it or is the bushing set just as important?
JohnnyB60 is offline
post #2 of 16 (permalink) Old 03-19-2012, 08:10 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
These shots may be of some help.
Harry
harrysin is offline
post #3 of 16 (permalink) Old 03-19-2012, 08:18 AM Thread Starter
First Name: Johnny
Thanks Harry, I was just about to go out to the shop and check it out.
Oh and Harry, I just love your router light and I'm going to do the same.
post #4 of 16 (permalink) Old 03-19-2012, 08:45 AM Thread Starter
First Name: Johnny
OK, I just opened my Ridgid universal busing set and realized that I have to drill my own holes. So now I guess that I need to make a decision on which router to use it on. I guess it will be on my Porter Cable.
I might have to wait a while because the shop is a little cold this morning and Iím going to need a lot of hot coffee.
post #5 of 16 (permalink) Old 03-19-2012, 08:56 AM
harrysin's Avatar
First Name: Harry
Then how about going all the way and make an illuminated base. I keep the one that I made on the router which is permanently mounted on skis.
PLEASE NOTE THAT THE BATTERY POLARITY IS SHOWN REVERSED
Harry
harrysin is offline
post #6 of 16 (permalink) Old 03-19-2012, 09:23 AM Thread Starter
First Name: Johnny
Oh wow, Iím going to do that, but Iím going to have to wait until get a little more proficient with the router. Thanks Harry
post #7 of 16 (permalink) Old 03-19-2012, 09:23 AM
Hi Johnny - what holes are you planning on drilling? I'm thinking that Ridgid bushing set should install directlly to your 890. If it's to install on your trim router, yes, you will likely need to make a new plate for it.
I read your other post also about top bearing bits and yes, they are very handy. They do have the downside in that the entire cutting length needs to be extended for them to work. You end up balancing the thickness of the guide material with the depth of desired cut with the cutting length of the bit..
I've had situations where I would have to change bits midway in the job because the bit I needed to start the job with didn't have the cutting length to finish it. Much less likely to happen with bushings. You do need to do the math exercises but after awhile they really become natural.
John Schaben
jschaben is offline
post #8 of 16 (permalink) Old 03-19-2012, 09:40 AM Thread Starter
First Name: Johnny
The Base doesn’t have any holes in it, they provide templates
post #9 of 16 (permalink) Old 03-19-2012, 09:48 AM Thread Starter
First Name: Johnny
..... If it's to install on your trim router, yes, you will likely need to make a new plate for it. ...
Now thatís a thought, can I do bushings in the trim Router? Since I learned how to use it and use the correct speed, it has become my favorite router.
post #10 of 16 (permalink) Old 03-19-2012, 09:51 AM
Hi
This is how I made my illuminated base
On-Point Universal Laser Guided Router Plate
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
Making templates based on designs done on the computer Vrtigo1 Guide Bushings and Templates 3 11-08-2011 11:55 AM
For Sale: Misc Router Inlay Templates dovetail_65 Woodworking Classifieds 3 02-21-2011 11:55 AM
Templates - table v. plunge routers charleyb Guide Bushings and Templates 5 06-03-2009 07:35 PM
help with making templates JTN89 Jigs and Fixtures 4 03-23-2009 12:53 AM
