dont know size of flush cut bit - Router Forums
post #1 of 8 (permalink) Old 04-23-2012, 07:12 PM Thread Starter
First Name: rchard
Default dont know size of flush cut bit
Hey guys I was wondering, i have some 5/8" stock stair treads that i have to cut down to a specific profile. I need to know before i buy the router bit which size bearing assembly i should buy either the 1/2", or the 3/8 " bearing. i don't even know if it matters but any help would be appreciated.
sealik84 is offline
post #2 of 8 (permalink) Old 04-23-2012, 09:15 PM
Bearings should be interchangeable, get extra bearing set.
I quite often swap out bearings to vary profiles depending on needs.
PS... I see you're talking about a flush cut bit. Normally I go with a bigger diameter for heavy stuff.
TomE is offline
post #3 of 8 (permalink) Old 04-24-2012, 07:04 AM
First Name: Art
Are you trying to round off the edges or some how change the edges? If so the bearing size doesn't matter as much as the radius size of the cutting edge. For example a 1/2" rounding over bit will give you a different look than a 3/4" bit. Also the height that the bit is set at will also affect the look.
mgmine is offline
post #4 of 8 (permalink) Old 04-24-2012, 11:20 AM Thread Starter
First Name: rchard
No i am just trying to cut off of a tamplate. and did not relize there were so many choices. i don't know if 1/2" or 3/8" matter when cutting srom the template.
sealik84 is offline
post #5 of 8 (permalink) Old 04-24-2012, 08:52 PM
If you can, rough cut the tread with a jig saw or similar leaving 1/8" or so to trim off with the router. Makes for an easier go of it.
TomE is offline
post #6 of 8 (permalink) Old 07-08-2012, 10:31 PM
First Name: Mal
For a flush trim bit, the bearing diameter and bit diameter are the same, so for a straight line cut following the pattern, 3/8 or 1/2 in should both work without any variation in the pattern. However if what you are making has an internal corner, any bit will leave a radius in the corner equal to the radius (half diameter) of the bit. If this might be an issue, the smaller the diameter, the smaller the corner radius that will be left.
Otherwise bigger is better, I normally use 5/8 or 3/4 skewed bits for external pattern following.
malb is offline
post #7 of 8 (permalink) Old 07-09-2012, 07:43 AM
CharleyL's Avatar
First Name: Charley
When doing this, the larger diameter bit will allow you to remove more material in one pass than smaller diameter bit. You should never try to cut away more than 1/2 of the diameter of the bit in one pass or you will experience serious chipping and splintering. Keeping the removal at 1/3 or less of the bit diameter produces the best results.
Charley
Central North Carolina
CharleyL is offline
post #8 of 8 (permalink) Old 07-09-2012, 08:55 AM
Honored Member
First Name: pat
"but any help would be appreciated"
I'd use a big fat bit, somewhere between 3/4 and 1" in diameter with a flute length that closely matches the thickness of the work.
And, of course, a collar and a plunger.
Maybe 2 or 3 passes/thickness. Why?
Very little tearout, the cutter can stand it, and there will be less chatter, as the collar transmits it vectors to the casting not the armature.
Straight bits are cheaper too & the collar guide bush is a safer way of routing.
Quillman is offline
What size of Raised Panel Bit? SandyT Table-mounted Routing 29 07-17-2006 10:34 PM
proper bit size Birchwood Router Bits - Types and Usage 2 09-17-2005 11:54 AM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 06:50 PM
RouterForums Amateur Night Rabbet bit Tables reible Router Bits - Types and Usage 1 10-10-2004 09:03 PM
