Help needed with Template use - Router Forums
post #1 of 14 (permalink) Old 05-03-2012, 12:05 PM Thread Starter
GulfcoastGuy's Avatar
First Name: Patrick
Default Help needed with Template use
I'm trying to upgrade my existing el-cheapo Wolfcraft Router table by adding some ring inserts but I'm failing pitifully.
Here's what I have.
The table top is almost identical to this. It's reinforced underneath with angle iron and fits in the center of a Shopmate style folding clamp table.
These are the rings I'm trying to add.
I'm using the MLCS inlay kit to try to match the OD of the outer ring but the pattern circle I make ends up giving me a circle that is just under 1/16 oversized all the way around.
Method used:
  1. using a pattern following bit make a 1/4" MDF disk the size of the largest diameter
  2. screw the mdf disk to the 1/4 MDF that will become the pattern circle
  3. create the pattern circle using the inlay kit without the outer bearing
  4. use the pattern circle, add the outer bearing to create the circle recess to fit the rings
After that I had planed to hog out inside the edge for the lip and then use a hole saw or make another pattern circle to cut the final through hole.
I did a test on some scrap and the result was over-sized as I stated above. I'm convinced its my technique that's causing my problems cause I modeled the method on Google Sketchup and it seems like it ought to work.
Any help will be appreciated.
GCG
GulfcoastGuy is offline
post #2 of 14 (permalink) Old 05-03-2012, 02:35 PM
kp91's Avatar
First Name: Doug
Is the bit you're using the one that came with the kit? If the bit isn't exactly the same diameter as the offset bushing thickness it's going to be off.
If your inlay kit has a screw on the bushing, tightening it too much could offset your bushing.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 14 (permalink) Old 05-03-2012, 02:43 PM Thread Starter
First Name: Patrick
I'm using only what was supplied with the kit. I checked the bit diameter against the bushing thickness and they match.
Good friction fit ... no screw.
Thanks for the responce
GCG
post #4 of 14 (permalink) Old 05-03-2012, 09:23 PM
Hi Patrick - I think I may be confused about what you are trying to do. If it is just to copy the size disc, hasn't that already been accomplished in step one of your procedure?.. with a pattern flush trim bit.. I don't quite understand needing the inlay kit at all here.
John Schaben
jschaben is offline
post #5 of 14 (permalink) Old 05-03-2012, 10:23 PM Thread Starter
First Name: Patrick
I'm trying to route out a recess in the table top to accept the rings with as close a fit as possible. The current hole has a limited clearance and I'd like the increased capacity for larger bits.
I'm starting to think that maybe the bit isn't staying fully vertical when I use the circle pattern because there's no support in the center and that better support may be the answer.
GCG
post #6 of 14 (permalink) Old 05-03-2012, 10:34 PM
GCG
Hi Patrick - ahaha - now I got it.
John Schaben
jschaben is offline
post #7 of 14 (permalink) Old 05-03-2012, 11:50 PM
Hi Pat
I have done it a time or two and it's Not a easy job,I would suggest you just make a new router table a simple apple box work bench type will do just find and just use a Fac.made router plate with the rings in place,you can get one for about 13.oo bucks..
no need to make a easy job hard
post #8 of 14 (permalink) Old 05-04-2012, 05:52 AM Thread Starter
First Name: Patrick
Hi Pat
I was starting to get to that point on my own.
I've got a ~10.5"x21" opening in my new table saw (Ridgid r4510) when the table is extended. Would the 10.5" leave enough meat to support a plate? If so then I could use the table fence with the router.
GCG
post #9 of 14 (permalink) Old 05-04-2012, 09:27 AM
Hi Pat
Should be fine at 10.5" you just need a 1/4" wide lip on all 4 sides to support the plate.
GCG
post #10 of 14 (permalink) Old 05-04-2012, 12:35 PM
stanzee's Avatar
First Name: Stan
Hi Pat
I also have a Wolfcraft table but the larger one on its own legs. The top seems to be adequate for my purposes at this time. In order to upgrade I installed a lift which naturally came with its own plate which has available other size rings. Without checking any further because of lack of time riight now I think you can find a plate to accept your router which also has changeable rings. The advantage of the larger plate as mentioned several times before is the stability it offers in controlling table flatness.
stanzee is offline
Template thickness question atmguru222 Guide Bushings and Templates 4 02-27-2011 08:20 PM
How to make a template accurate? Steve Blackdog Guide Bushings and Templates 4 01-02-2011 03:44 PM
Template guides question needlerockrick New Member Introductions 4 01-29-2010 09:23 AM
inlay template needed! wrestlingstud13 Guide Bushings and Templates 7 03-30-2009 06:28 PM
