Drilling Pen Blanks with a Radial Arm Saw (RAS) - Router Forums
post #1 of 9 (permalink) Old 05-18-2012, 11:35 PM Thread Starter
allbarknobite's Avatar
First Name: Mark
Default Drilling Pen Blanks with a Radial Arm Saw (RAS)
Hi all,
I have also drilled pen blanks using a drill chuck attached to a radial arm saw (RAS).
An advantage is being able to use a longer drill bit because of the long parallel travel of the motor.
A disadvantage is that the drill chuck would only take up to 8 mm pen drilling bits.
I could not find a larger drill chuck that would fit on the threaded motor shaft on my RAS made in 1973.
The motor runs at 3450 rpm, so the safety minded workers should be happy.
Attached are a series of images that show the layout.
In the pictures, nothing is shown attached to the saw.
The drill vise holding the pen blank, must be aligned and securely anchored to the table.
Mark
Name:	b-RAS chuck.JPG
Name:	c-RAS drill setup.JPG
Name:	d-RAS drill view left.JPG
Name:	e-RAS drill view right.JPG
Name:	f-RAS drill aligned.JPG
Name:	g-RAS drill max depth.JPG
allbarknobite is offline
post #2 of 9 (permalink) Old 05-19-2012, 08:21 AM
drill chuck at a great price
http://www.ebay.com/itm/1-pc-key-1-1...item20c2725e58
1 pc SDS plus Adapter & 1/2" CAP Drill Keyless Chuck | eBay
post #3 of 9 (permalink) Old 05-19-2012, 08:22 PM Thread Starter
First Name: Mark
Thanks for finding those drill chucks on eBay, but the 5/16-24 external post on the chuck that I have is hard to pin down.
The DeWalt ras motorshaft has a 5/16-24 female thread on the accessory end.
Do you know of an "adapter" that I can use to upsize to the chucks you suggested?
It would have to go from 5/16-24 male to 3/8" 24UNF male (or larger) to use the drill chucks on the market. So far I haven't found one.
Thanks again,
Mark
post #4 of 9 (permalink) Old 05-19-2012, 09:08 PM
Hi Mark
Sorry I don't off the top of my head
But if you have a lathe or have mate that has one you can make your own easy just pickup a 1/2-20 Allen set and turn the end down to 5/16 and put the threads on it, the 1/2-20 drill chucks are easy to find
Or just pickup the chuck below and turn the adapter down on one end to 5/16..
http://www.ebay.com/itm/1-pc-SDS-plu...7331b5&afsrc=1
Thanks again,
Mark
post #5 of 9 (permalink) Old 05-20-2012, 09:08 PM Thread Starter
First Name: Mark
Default Thanks for your good advice.
Thanks for the update.
I took your advice, went to eBay and will machine the end.
I went for the standard chuck as shown in the picture.
Thanks again,
Mark
post #6 of 9 (permalink) Old 05-20-2012, 09:34 PM
You're Welcome Mark
Here's little tip chuck up a 1/2-20 nut in the lathe ,that way you will not screw up the threads on the adapter but I'm sure you know that
post #7 of 9 (permalink) Old 05-21-2012, 08:03 PM
rwl7532's Avatar
First Name: Ralph
I thought this would be a great upgrade for my drill. BIN on Saturday. Showed up in my mail TODAY (Monday).
Wow.
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #8 of 9 (permalink) Old 05-21-2012, 08:31 PM Thread Starter
First Name: Mark
Default lathe chucking using a 1/2-20 nut
You're Welcome Mark
Here's little tip chuck up a 1/2-20 nut in the lathe ,that way you will not screw up the threads on the adapter but I'm sure you know that.
Jigs
Thanks for the tip on chucking up a 1/2-20 nut to hold the part for threading.
Until you suggested it, it didn't cross my mind that I would have to use extra care.
Doing your way will probably produce Minimum Runout on the new threaded adapter.
Mark
post #9 of 9 (permalink) Old 05-22-2012, 08:16 AM
Knothead47's Avatar
RAS to drill! I would have never guessed! Got a couple of old motors- will check to see if they are threaded on the backside.
John T.
Knothead47 is offline
cutting jig for pen blanks jd99 Woodturning and Lathes 16 02-26-2013 12:01 PM
Drilling Pen Blanks with a Router Table allbarknobite Guide Bushings and Templates 14 05-18-2012 11:01 PM
Dewalt Radial arm saw jetpilot Tools and Woodworking 8 07-12-2010 02:47 PM
Radial Arm Saws. Still used? CanuckBeaver Tools and Woodworking 35 03-14-2010 05:56 PM
Radial Arm Router cabinetman Tools and Woodworking 12 04-27-2007 10:22 PM
