Using a portion of a template to make a project - Router Forums
post #1 of 3 (permalink) Old 06-08-2012, 09:31 AM Thread Starter
kp91's Avatar
First Name: Doug
Default Using a portion of a template to make a project
I should have posted these a while back, hopefully they'll be valuable for someone in the future.
I had to make a ship's wheel for a pirate graveyard display for a Girl Scout halloween function a few years back. My father was kind enough to loan me the wheel, but I didn't think he would want it left in the yard for a few days. The solution was to copy it and reproduce it out of something 'disposable'. I thought about just tracing it and cutting it out with a jigsaw, but I doubt I would have had any luck getting it to look remotely symetrical. An obvious solution was a template.
I traced it on to 1/4 inch MDF (I wish I had used 3/8, that would have given more bearing surface to ride on) but only traced a quarter of the wheel. I used my scrollsaw to cut it out, and found that 18" of throat depth wasn't quite enough, I had to cut the interior out in 2 steps. A little bit of sanding to refine the shape just a little and I had the template.
I put the template on to a piece of 3/4 mdf, and traced it's outline. I drilled an index hole at the center of each spoke, and transferred them to the MDF. I did a test, spinning the template, putting a nail in the index hole and tracing the outline until I got all the way around. I missed the final index hole by just under 3/16 inch, but the the outline I had traced on the sheet looked good.
I cut out the bulk of the material with the jig saw and started routing. I used 2 different pattern bits, one that had a 1/2 inch cutting depth, and one that had a 1 inch cutting depth. This let me nibble away at the waste keeping the bearing on the template. When each section was done, the template was rotated.
The finished result was a success, and a pretty respecable copy. It was finished with matte black paint and satin poly.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #2 of 3 (permalink) Old 06-08-2012, 09:49 AM
harrysin's Avatar
First Name: Harry
Your skills Doug certainly don't end with marine engineering! That was excellent.
Harry
harrysin is offline
post #3 of 3 (permalink) Old 06-08-2012, 02:45 PM
OPG3's Avatar
First Name: Otis
Doug - that is some very smart execution! Just looking at this makes me want to eat at Red Lobster. That's from being hungry and impressed! Making and using templates can require a lot of creative imagination and you hit the nail on the head! I'm currently making some router templates for an ammo manufacturer to go on his automated bullet stacker - accuracy is so much the key to effective indexing!
OPG3
Tweak everything!
OPG3 is offline
Joke a Day bobj3 Lobby 4339 Yesterday 06:07 PM
Cutting Board, Rounded Corners w/Juice Groove bradleyjere Guide Bushings and Templates 16 09-20-2011 09:48 PM
How to Make a Pencil Box learnexperience Tools and Woodworking 2 08-09-2011 11:45 PM
RouterForums Amateur Night?????? reible General Routing 44 02-10-2009 10:55 PM
