Beginner Question: Should/Could I use a template to cut a hole like this? - Router Forums
post #1 of 10 (permalink) Old 08-06-2012, 01:57 PM Thread Starter
First Name: David
Default Beginner Question: Should/Could I use a template to cut a hole like this?
I'm working on a guitar amp project that requires me to cut two holes through the front baffle of the enclosure. I need the holes to be precise. The corners are 1/2" radius and the entire baffle is 14" wide. I thought about using a drill press for the corners and jig saw to connect them, but my previous experience makes me thing it will be too rough.
What do you suggest?
Thanks for your help.
dbishopbliss is offline
post #2 of 10 (permalink) Old 08-06-2012, 01:59 PM Thread Starter
First Name: David
Default Might help if I remember to attach the image
Forgot the image... I want to route out the black parts.
post #3 of 10 (permalink) Old 08-06-2012, 04:51 PM
You can build a template out of straight pieces that have been cut on a table saw. If you make it out of lumber, you can screw the cross pieces to the stiles. I don't know the scale involved but the middle crosspiece may be a bit of a concern. It either needs to be stiff enough to avoid bending when you use it for a guide or you'll have to screw it to your workpiece. Once you've done this I would mount the template below your workpiece and use a bottom bearing flush trimming bit and follow the template. You don't need to worry about radiusing the corners of your template, the router bit will do that for you. The size of the bit will determine the size of the radius so you'll need a 1" bit. I would do the large cutout first.
post #4 of 10 (permalink) Old 08-06-2012, 05:32 PM
Good idea, Charles.
I had not considered using the template on a router table.
I see from his profile, that David has a router table.
I was going to suggest a template and skis to carry the router over the large gap.
Sydney, Australia
jw2170 is offline
post #5 of 10 (permalink) Old 08-06-2012, 05:45 PM
the same way as the items are made below,use 1/4" thick MDF and just glue it for your template(s)
Daisy Pin Router
see video
Router Templates - Oval Tray Template
New Products - 5 Section Template
New Products - 2 Piece Triangle Template
New Woodworking Products | New Woodworking Tools | Eagle America
post #6 of 10 (permalink) Old 08-06-2012, 09:58 PM
First Name: Wayne
I would make some templates to fit the areas you need to route out. Then use a jig saw to cut the areas out except for the last maybe 1/ inch. Depends on how comfortable you are with a jig saw. Then lay the templates across the piece and finish routing out to the lines, then sand. The templates can be made just 1/16 of an inch shorter in height so you can clamp them in place to your bench. This should relieve most of the stress on the small bar along the top. Hope this helps.
Making saw dust in Turtle Creek, PA.
Wayne
WayneMahler is offline
post #7 of 10 (permalink) Old 08-06-2012, 11:18 PM
neiltsubota's Avatar
First Name: Neil
Have you tried the "Lenox Hole Saws" ?
I personally have used this product to drill a 2" hole for an underground irrigation system I just finished last week.
These hole saws require a special arbor, that drills the pilot hole, before the 2" saw kicks in. You have to be careful because the saw can "bite", but for the most part. This was a better hole than I could have drilled with out the Lenox Hole saw.
Check this link:
Shop Tools at Lowes.com
Make sure you get the arbor. I bought an L-2 arbor for a 2" hole.
neiltsubota is offline
post #8 of 10 (permalink) Old 08-07-2012, 09:25 AM
harrysin's Avatar
First Name: Harry
I would suggest that you make a template from separate pieces of 3/8" MDF glued together in a similar way to that shown here. This method ensures perfect "cut-outs".
Sit the template on the wood to be used and draw the outline around the inside of the template. Now you can cut-out the waste using a jig saw, leaving about a 1/4" all round. The work piece and template can now be sat on each other by the use of double sided tape or pinned. The assembly is now sat over a 1/2" straight bearing bit with the template on top and rotated from left to right. The whole process, less glue drying time won't take much longer than it has to make this post.
Name:	ring box22.jpg
Harry
harrysin is offline
post #9 of 10 (permalink) Old 08-07-2012, 11:14 AM
Personally, I like Charles, Cherryville Chuck, suggestion however, just a caution on doing an inside cut on the router table. One must stay very focused on the bit rotation as it is pretty easy to get on the wrong side of it. DAMHIKT.
John Schaben
jschaben is offline
post #10 of 10 (permalink) Old 08-10-2012, 02:16 PM Thread Starter
First Name: David
Thanks guys. This is helpful. I didn't think about using a 1" bit and letting the bearing do the corners for me. That's why I asked.
Half Blind Router Template Question stevek433 Guide Bushings and Templates 5 02-06-2009 08:23 AM
Tom.... Question On Template Holder.. challagan Guide Bushings and Templates 16 02-21-2007 08:36 PM
Question about test cut graywolf General Routing 1 10-21-2006 09:54 PM
Question about uneven cut AndyGTC Starting Off 3 08-31-2006 12:05 PM
Router template question Sebisant General Routing 1 10-05-2005 06:10 AM
