Oversized guide bushings and storage - Router Forums
 4Likes
  • 1 Post By Mike
  • 1 Post By bobj3
  • 1 Post By neiltsubota
  • 1 Post By Mike
post #1 of 8 (permalink) Old 09-09-2012, 07:22 AM Thread Starter
Default Oversized guide bushings and storage
The vast majority of people in North America use Porter Cable(PC) style guide bushings. Many companies produce good quality brass versions, I like the set from Woodcraft the best. I am betting most people are not aware that you can buy larger sizes from PC. Shown are the 1-1/4 and 1-1/2" guide bushings, you can also buy a 1-3/8" bushing; cost on these is $14.67 each without a ring nut. (I got these from a discount box at a tool seller for $2 each)
While most guide bushing sets come in blow molded plastic boxes the best way to store the bushings for easy access is to make a tray similar to the one shown in the photo. For people who own a Router Workshop table the dimensions are 9-3/4" W x 11" L x 3/16" thick. This tray rides in 1/4" slots. While the one shown is for the larger Oak Park/Lee Valley style bushings you can easily make one for PC style bushings and reducers. Note the holes drilled for storing starting pins, set up pins and even the allen wrench used for the inlay bushings. 3/16" is a common thickness for Masonite.(Tempered High Density Fiberboard)
Name:	Guide bushing set.jpg
Name:	PC oversized GB.jpg
Name:	GB storage01.jpg
Roggerwood likes this.
post #2 of 8 (permalink) Old 09-09-2012, 11:16 AM
just one more way to keep track of them and to store them..
post #3 of 8 (permalink) Old 09-22-2012, 09:56 PM
neiltsubota's Avatar
First Name: Neil
Default 1.25", 1.5" & 1.375" What size is the hole in the base ?
Hello Mike,
Of the 3 sizes you mentioned above, what is the size of the hole in the base plate ?
Is this an "inverted" router for table top routing, or is this "upright" with the base-plate against the work piece.
Thanks for you help.
Neil
neiltsubota is offline
post #4 of 8 (permalink) Old 09-22-2012, 11:50 PM Thread Starter
Neil, these are PC style bushings and fit the standard 1-3/16" through hole. As with all PC style guide bushings they can be used in a table or freehand.
post #5 of 8 (permalink) Old 01-07-2014, 02:45 PM
Heinrich's Avatar
Hi Mike have you had to buy any new brass guide from oak park the large one. I brought a full set a few year ago. now I have lost one and have gone back there to order one but it looks like they are going out of business? do you know any other place that you can buy the large guide 1 1/2.
Ray Heinrich
Heinrich is offline
post #6 of 8 (permalink) Old 01-07-2014, 03:40 PM
1-3/4" Brass Template Guides - Lee Valley Tools
post #7 of 8 (permalink) Old 09-04-2016, 11:06 AM
First Name: Scott
I am interested in finding a 1-1/2" OD template guide that will fit a standard 1-3/8 porter-cable socket.
Do you have a source for this?
scottgrove is offline
post #8 of 8 (permalink) Old 09-04-2016, 11:40 AM
Welcome to the forums Scott...
as for your question...
Oak Park should be able to give you what you want...
at least give them a call...
1.800.665.0252
Oak Park Enterprises Ltd. - Router Table, Router, Router Bits, Router Jigs, Router Accessories
Bit storage plastic bushings over40pirate Router Bits - Types and Usage 2 08-09-2009 02:00 PM
