..I don't fully centering ... - Router Forums
post #1 of 4 (permalink) Old 09-15-2012, 11:52 PM Thread Starter
First Name: Rob
Default ..I don't fully centering ...
Hi...first post..
I bought a 'universal' base plate to use with guide bushings (& some guie bushings). There's a fitting included that is like a 1/4" cylinder with a cone on one end.
I need an 'idiot sheet' since I don't get what & when I'm supposed to do with it.
Also I have an 'inlay' kit with a removable spacer and a different centering part.
I have looked through the forums..but I'm still in the dark.
Can some explain in the most basic terms what the steps in the processes for each system ..please?
Thanks, Rob.
RobSm is offline
post #2 of 4 (permalink) Old 09-16-2012, 12:01 AM
LuisG's Avatar
Country: Mexico
First Name: Luis
I think this may help..
On youtube search for: Inlay With A Router.. from user stockroomsupply (sorry I cant put URLs yet)
Good luck!
Luis
Originally Posted by RobSm View Post
Hi...first post..
Thanks, Rob.
LuisG is offline
post #3 of 4 (permalink) Old 09-16-2012, 12:04 AM
Hi Rob
They both work well but the inlay kit works the best,just pop in the guide in the router base and use it to line up the plate,once you have the base screw down in place you are set to use the other guides as well.
The cone type works about the same,pop in a 3/8"/1/2" guide the norm and do the same as the inlay setup..
http://manuals.harborfreight.com/man...9999/99552.pdf
==in
Hi...first post..
Thanks, Rob.
post #4 of 4 (permalink) Old 09-16-2012, 07:17 AM
First Name: David
Default centering bit
the kits I got have a bit which is 1/4 in on one end and 1/2 in on the other. This is to allow centering using either a 1/2 in router or a 1/4 in router. Just depends on which end fits in your router.Be glad to email you the instruction sheets I have for my kits if you want them.
<[email protected]>
Skyewalker is offline
Centering your router on a mounting plate Mike Table-mounted Routing 61 01-08-2016 10:28 AM
Bosch Centering Cone JudgeMike General Routing 19 04-30-2012 11:47 AM
Centering cone? fooser Table-mounted Routing 7 09-08-2011 02:46 PM
router centering guide for centering inlay bits frankb General Routing 1 02-25-2011 02:00 AM
Incra Auto Centering Scale Zurt Table-mounted Routing 1 01-24-2011 10:07 AM
