Any one for quoins? - Router Forums
post #1 of 13 (permalink) Old 11-16-2012, 03:10 PM Thread Starter
First Name: Ben
Default Any one for quoins?
As many other users of this forum, I have gathered many good ideas and new and faster ways of creating sawdust. I am in the process of following several of Harry Sims Videos. (Thank you Harry)
Yesterday I finished my router skis. It is not pretty but should work OK. Also completed was a Jig for holding work pieces in preparation for inlaying.
As you know the inlay jig comprises several components including a rectangular fixed frame that surrounds the work piece which will be routed to receive the inlay.
Harry shows two ways of clamping the work piece to the base of the Jig. Method 1 shows nailing scrap wood around the work piece. Method 2 shows cams.
Looking at the entire system I had a flash back to my high school print shop (many long years ago). Type was prepared for printing by blocking the type into a fixed metal frame. This was much like blocking a wooden work piece into Harry's Jig.
The type is blocked into the frame by blocks of wood. Several blocks of wood spacers are inserted loosely between the block of type and the fixed frame. To tighten these spacer blocks a pair of metal wedges called quoins were inserted. We used the Hempel Style Quoins. They were wedges formed with gear teeth on the inside mating faces. the quoins would be placed between the wooden spacer blocks and tighten by a tee shaped quoin wench.
I think that this method would be a great way to block up a work piece for inlaying.
I have looked on E-Bay and found a couple of listings for quoins and quoin wrench. The items were apparently being sold as antiques and were priced accordingly.
Does anyone out there know if quoins are still commercially being produced?
If so, please give me a source.
Ben
Forest Reduction Study Group
Ben in Cypress Texas is offline
post #2 of 13 (permalink) Old 11-16-2012, 06:29 PM
Ben
Hi Ben - I just cut wood wedges from 1x stock. I chop up several pieces of 1x stock into 8" lengths and use a tapering jig on the table saw. I make one end about 1/4" thick and taper out to about 3/4".
John Schaben
jschaben is offline
post #3 of 13 (permalink) Old 11-16-2012, 06:51 PM
just one more way
post #4 of 13 (permalink) Old 11-16-2012, 07:39 PM
I have to agree with BJ on using the Router Workshop method. It is quick and easy as well as being infinitly adjustable. Poplar BJ?
post #5 of 13 (permalink) Old 11-16-2012, 09:02 PM Thread Starter
First Name: Ben
Gentlemen
Thanks for your response. I have a taper jig and will cut some wedges.
BJ is see that in your photo you have a Milescraft Design Inlay Kit. Mine just arrived UPS this afternoon. I haven't had time even to watch the enclosed DVD.
How do you like yours? any comments or cautions?
Regards
Ben
post #6 of 13 (permalink) Old 11-16-2012, 09:42 PM
Hi Mike
Poplar=Yes
post #7 of 13 (permalink) Old 11-16-2012, 09:43 PM
N'awlins77's Avatar
First Name: Lee
I have one too (Milescraft Inlay kit) but haven't had a chance to "play" with it yet.
N'awlins77 is offline
post #8 of 13 (permalink) Old 11-16-2012, 09:49 PM
Hi Ben
Yes that is the Milescraft inlay setup,I do like it ,it can used in many ways I do like the brass milescraft guides over the plastic ones I have melted down one or two of the plastic ones..my error getting the bit to close to the bit..
The drop in block is for the router table setup for the Router Workshop plate setup 11" x 11" but it can be for any size hole you have on your router table.. see below.. no clamps needed.
Gentlemen
Regards
Ben
post #9 of 13 (permalink) Old 11-16-2012, 10:02 PM
Thumbs up
Hi Ben
Ordered mine yesterday, from Peachtree.
Sydney, Australia
jw2170 is online now
post #10 of 13 (permalink) Old 11-17-2012, 06:29 AM
Hutzul's Avatar
Red face Who Is Harry Sims ?
Ben
Hi Ben. I've been trying to find Harry Sims on youtube and also google, all I get is those cartoon characters.........
Will you ( or some kind soul) put me out of my misery and provide a link to Harry Sims please, pretty please ?
Cheers guys
Hutzul is offline
