Making a male part for a female part - Router Forums
post #1 of 29 (permalink) Old 11-26-2012, 11:48 PM Thread Starter
First Name: Chris
Default Making a male part for a female part
I have already made the holes for my new router table. They are 10x12", ani I made them with a 3/4" bit, so I have a 10x12" hole with rounded corners.
I'm sure there is a way using bushings to make a male piece that fits it, but I'm having a little trouble figuring out how to set it up.
Can someone point me to a good reference for it?
Chris Curl is offline
post #2 of 29 (permalink) Old 11-27-2012, 12:09 AM
Chris, I assume you want to cut a plate to fit in that space?
It is relatively easy to calculate the template if you know what cutter you are going to use.
Also, are you going to use a bearing guided cutter or a cutter in a template guide?
In this case, remember that you want to keep the "inside" of the cut.
Sydney, Australia
jw2170 is offline
post #3 of 29 (permalink) Old 11-27-2012, 12:52 AM Thread Starter
First Name: Chris
thanks james. i THINK i may have figured it out ...
if i use a 1/4" flush trim bit to make a male template by carefully following the inside of the hole, then i use a 1/4" bit in a 3/4" outside diameter bushing/template guide, i SHOULD get a male part that fits the hole pretty much exactly.
or if i use a bushing and bit combo that gives me a template that follows the inside edge of the female XXX", then one that follows the outside of the template by the same amount will do it for me.
for my 3/4" radius rounded corners, the male needs to be at most 3/8" smaller than the female. otherwise, the corners will be malformed when i make the inserts. so in this case, XXX can be at most 3/8".
does this sound reasonable?
post #4 of 29 (permalink) Old 11-27-2012, 05:19 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Why not use the table saw to cut a piece the exact length and width then rout the corners round like in these shots.
Harry
harrysin is offline
post #5 of 29 (permalink) Old 11-27-2012, 06:53 AM
Chris
How about the jig below you don't need to buy one you can make your own.
Amazon.com: Trend VARIJIG Frame System: Home Improvement
http://www.youtube.com/v/xtgbgwfBnak&autoplay=1&rel=0
post #6 of 29 (permalink) Old 11-27-2012, 07:19 AM
What Harry said, except you used a 3/4 bit so you just have a 3/8" radius, personally, I'd just sand it.
John Schaben
jschaben is offline
post #7 of 29 (permalink) Old 11-27-2012, 08:19 AM
harrysin's Avatar
First Name: Harry
Are you sure about the 3/8" radius John?
Harry
harrysin is offline
post #8 of 29 (permalink) Old 11-27-2012, 09:30 AM Thread Starter
First Name: Chris
Harry and John, that was my original idea, but I thought this might be a good opportunity to learn how templates and guide bushings work and understand the math behind it.
Now that I understand it a little better, I think I can make a rectangular piece with square corners (on the table saw) that is 3/4" shorter and narrower than the opening. Then if I use a 1/4" bit with a 1" OD bushing, I will get a 3/8" offset on each side and the corners should be rounded with a 3/8" radius.
harry: yes, since i used a 3/4" wide bit, it has a 3/8" radius.
bob, I'm not seeing how I can use that to make the male part with rounded edges. That would result in a piece with square corners.
post #9 of 29 (permalink) Old 11-27-2012, 10:11 AM
First Name: Art
Chris I'm not sure what you are trying to do are you trying to make your plate lay flat on the table? Is the plate larger than the hole in the table? If so then you need to use a rabbiting bit to make the recess in the top to accept the plate.
mgmine is offline
post #10 of 29 (permalink) Old 11-27-2012, 10:56 AM
Hi Chris
Any time you use a round cutting tool or a round guide on a inside corner of a frame/template jig you will end up with round corners like a 3/4" or 1" guide and 1/2" router bit..
Making a Birdhouse BernieW Woodturning and Lathes 9 03-28-2009 10:34 PM
Making a vase part 3 chippypah Woodturning and Lathes 10 03-05-2008 07:42 AM
Making a vase part 2 chippypah Woodturning and Lathes 1 03-04-2008 10:37 AM
Making a vase part 1 chippypah Woodturning and Lathes 0 03-04-2008 02:23 AM
Making a small 3x5 inch part. Kristin D Jigs and Fixtures 0 12-13-2007 04:58 PM
