Should I shorten bushings? - Router Forums
post #1 of 10 (permalink) Old 12-05-2012, 07:06 AM Thread Starter
Default Should I shorten bushings?
I've setup some guides to trim the inside faces of the new jaws on my Workmate. I'd like them to mate tightly and right now their are some gaps. I'm using this as an opportunity to practice using the router to make mating edges.
However, the fence material I've used is 3/8 and the bushings are a bit taller than that (more like 1/2"). I'd prefer not to have to change fences - would I be losing any significant functionality if I shorten the bushings?
Thanks,
Jim
jmoore65 is offline
post #2 of 10 (permalink) Old 12-05-2012, 07:37 AM Thread Starter
I decided I'd not done my homework and did a search for "bushings shorten" and found this thread: http://www.routerforums.com/guide-bu...shings+shorten that answers my questions.
So - I have a follow-on question - what is a good thickness for template materials when using a bushing?
Thanks,
Jim
jmoore65 is offline
post #3 of 10 (permalink) Old 12-05-2012, 07:42 AM
kp91's Avatar
First Name: Doug
I like 3/8 inch if I'm using MDF, but I've made plenty of 1/4 inch ply and masonite templates over the years.
In addition to the other methods of shortening bushings, I've 'fine tuned' a couple with a quick touch to the belt sander.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 10 (permalink) Old 12-05-2012, 10:58 AM
MikeMa's Avatar
I have shortened a couple of my brass bushings with no ill-effect. I actually used my lathe (note clean any sawdust up around it before doing this) to do this. I chucked up with enough pressure for it to stay in the lathe, but taking care not to deform the bushing. Turn the lathe on to about 300-400 rpms, and then used a file to bring it down. This also enabled me to put a bevel back on at the tip as well.
As always for any use of the lathe, always use a faceshield.
MikeMa is offline
post #5 of 10 (permalink) Old 12-05-2012, 04:53 PM
Pat Warner shows an easy way to shorten the guide bushing in his DVD "The Versatile Router".
Bob and Rick, I believe, used mainly 1/4" material for their templates, so the bushing should be less than 1/4".
Sydney, Australia
jw2170 is offline
post #6 of 10 (permalink) Old 12-05-2012, 05:57 PM
This is why I suggest the Woodcraft PC style guide bushing kit which is designed for use with 1/4" template material. Both of the larger Oak Park/Lee Valley style bushing sets use 1/4" template material too.
post #7 of 10 (permalink) Old 12-05-2012, 07:22 PM
Thanks, Jim
Hi Jim - Won't hurt a thing. I have a couple sets of the Eagle America bushings which are .201 long. I use the bandsaw for shortening longer ones. Put a hole in a piece of 1/4" MDF, or, better yet, a piece of 5.2 mm plywood to put the barrel through. Set the bandsaw fence so that you can use the MDF/plywood for the blade guide and slide it through. Will likely want a little deburring when you're done.
John Schaben
jschaben is offline
post #8 of 10 (permalink) Old 12-05-2012, 07:26 PM
First Name: Drew
Thanks,
Jim
It's nice to be able to stack pieces when creating your master pattern.
~1/4" of bushing lets you stack two pieces with 1/8" hardboard on top. A taller bushing lets you stack more.
Drew Eckhardt is offline
post #9 of 10 (permalink) Old 12-05-2012, 10:34 PM
That's true Drew - the tradeoff is, the longer the bushing the less depth of cut you have. Everythings a tradeoff
John Schaben
jschaben is offline
post #10 of 10 (permalink) Old 12-06-2012, 04:19 PM
Phil P's Avatar
First Name: Phil
Hi Jim
Faced with this sort of a problem out on a job site I'd probably opt for adding a 1/8in 93mm) or 1/4in (6mm) thicjk MDF or plywood sub-base to the bottom of the router. saves having to butches stuff - and in any case I don't carry a bandsaw
Regards
Phil
Phil P is offline
Oversized guide bushings and storage Mike Guide Bushings and Templates 7 09-04-2016 11:40 AM
Metric bits and guide bushings Mike The Voting Booth 29 05-09-2012 09:08 AM
Base plates that recieve guide bushings TanOak Table-mounted Routing 10 10-15-2011 09:55 AM
Harbor Freight Guide Bushings Work Better. RJM60 Guide Bushings and Templates 0 08-02-2010 05:06 PM
PC style bushings in Woodpecker plates the_nite_owl Guide Bushings and Templates 2 01-11-2010 12:22 PM
