Having a Template made - Router Forums
post #1 of 9 (permalink) Old 02-05-2013, 05:30 PM Thread Starter
Marco's Avatar
Default Having a Template made
Has anyone had a template made buy a laser cutter or CNC? As you can tell it is all new to me but if reasonably priced it would be well worth it. I recently engraveved free hand a piece that took 4 hours when you add up all of the pre and post routing. There was too much detail for me to make a "usable" template but if I had a template, routing time wouldn't be but maybe 20 minutes. I assume all they would need would be the artwork?
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #2 of 9 (permalink) Old 02-05-2013, 07:24 PM
Phil P's Avatar
First Name: Phil
Hi Marco
Some, but not all, CNC shops can scan and convert the scanned image to artwork. They might have to clean up the image. For this there would be an origination/conversion charge. Other shops require the drawing converted to a CAD format such as Autocad DXF. Best to enquire.
Regards
Phil
Phil P is offline
post #3 of 9 (permalink) Old 02-05-2013, 07:41 PM Thread Starter
Marco's Avatar
Thanks Phil, I've been googling steady since I've posted and have found only one CNC shop online. I would guess that there are thousands but I haven't found them. The template to be made is basically a logo with a little design. I emailed them but would like more hooks in the water
Marco is offline
post #4 of 9 (permalink) Old 02-05-2013, 11:05 PM
Hi Jim, have you tried yellow pages for your area?........
Some small business's do not have web sites.
Sydney, Australia
jw2170 is offline
post #5 of 9 (permalink) Old 02-06-2013, 06:26 AM
boogalee's Avatar
First Name: Al
Try posting in the CNC routing section. It may be possible for some one to create a template for you.
Al
boogalee is offline
post #6 of 9 (permalink) Old 02-06-2013, 11:01 AM
MEBCWD's Avatar
Hi Jim,
Send me an email or PM with details of what you need and I can give you and estimate for a set of templates to cut your project.
MEBCWD is offline
post #7 of 9 (permalink) Old 02-06-2013, 11:49 AM
post #8 of 9 (permalink) Old 02-06-2013, 09:33 PM
SteveMI's Avatar
First Name: Steve
I have a CNC and made templates before. The biggest time is getting "artwork" into a vector graphic and then create a cutting path. Some people are faster at it. The Vectric V-Carve and Aspire software is supposed to do that very easily. I covet it, but don't have it.
Steve.
SteveMI is offline
post #9 of 9 (permalink) Old 02-07-2013, 04:27 PM
Mike Wingate's Avatar
First Name: mike
I have access to a Laser at school. I avoid it. I prefer to cut my templates out using my Hegner scroll saw. I use Lexan so I can see through my templates. The Lexan cause gas problems with the Laser. I CAD my designs and stick them onto the Lexan.
Mike Wingate is offline
How to enlarge Template tigerhellmaker Jigs and Fixtures 9 06-08-2010 05:09 PM
how to trace a reduced template for bushing offsets steph33 Guide Bushings and Templates 4 05-01-2010 02:30 PM
Template guides question needlerockrick New Member Introductions 4 01-29-2010 09:23 AM
