Quick Copier Router Idea(s)?? - Router Forums
post #1 of 7 (permalink) Old 02-27-2013, 04:51 PM Thread Starter
Default Quick Copier Router Idea(s)??
Hi,
Needing to quickly create a router setup for copying some profiles..
As attached image, was thinking 2 pieces of board (one 500 x 1000mm and other 500 x 500mm) both as coloured blue. The yellow is the 1000x1000mm "area" the copier would need to span. Roughly show a cutter and follower attached to top board. Seems a lot of wood to me! ;-).. Any ideas for simple track mechanism to allow the movements as shown with arrows?. i suppose I could use draw sliders but must be something simpler in wood?.. Do i need all that board also? ;-)
All input greatfully appreciated..
M
millipee is offline
post #2 of 7 (permalink) Old 02-27-2013, 04:54 PM Thread Starter
in fact the MAXIMUM area to copy is within a 500x500 (bottom left yellow area) which is why i have the yellow as 1000x1000 to allow full movement (extremities of track i suppose).. must be a better design that this.. and easier to make ;-)
millipee is offline
post #3 of 7 (permalink) Old 02-27-2013, 06:07 PM Thread Starter
just thinking about it.. could you copy something if existing shape (or shape to copy) were positioned overhead?.. maybe 500mm above?.. does that simplify an approach?
millipee is offline
post #4 of 7 (permalink) Old 02-27-2013, 08:37 PM Thread Starter
rather than board.. suppose i could use tubes and blocks that they slide in to?... rather than expensive slide bearings there may be something in nylon/cheaper?.. maybe something readily available at the DIY store?.. as attached image... thoughts
Originally Posted by millipee View Post
Hi,
M
millipee is offline
post #5 of 7 (permalink) Old 02-27-2013, 08:58 PM
Hi N/a.
Maybe a photo of what you are trying to copy would help.
If all you are doing is copying a profile, I cannot see why a template trim cutter will not work?
Wealden Tool Company Limited Housing Rebate - guided
Sydney, Australia
jw2170 is offline
post #6 of 7 (permalink) Old 02-27-2013, 09:28 PM
Phil P's Avatar
First Name: Phil
Hi James
I'm left with the impression that the item the OP is copying is a 2-1/2D object, i.e. an object with a series of flat planes at different levels as opposed to a true contoured 3D object. If so the template trimmer will only rout the outside edge and might be too deep.If n/a could answer this (or even add his name to his profile?) I'd be grateful
Nice to see you've found a decent tool supplier
Regards
Phil
Phil P is offline
post #7 of 7 (permalink) Old 02-28-2013, 08:40 AM
Here is the principle I would recomend you consider.
Keith MacKenzie's Pantograph The FL Guitar Builders Ass. Meeting - YouTube
This is for inlay, but a pattern on one side and router on the other side works the same way.
flockshot is offline
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Quick change router mount? archangel Table-mounted Routing 12 01-17-2008 01:51 PM
