How to route a corner radius - Router Forums
post #1 of 5 (permalink) Old 03-10-2013, 09:52 AM Thread Starter
First Name: Ray
Default How to route a corner radius
Hi All,
Brand new to routing. My first project is building a router table. I got the Kreg Precision router table insert and I'm trying to route out a hole for it to drop through (not a rabbet).
I screwed down some wood that fits snug to the router plate and routed the inside of it with a 1/2" bottom bearing flush trim bit. Unfortunately, my corners don't have the correct corner radius. The specs say the corner radius is 3/4" on the plate, how would I go about making a template to route this out?
I've tried free-hand with an orbital sander, jig saw, the router, suffice it to say I need a template to do this properly..
Thanks!
Raystafarian is offline
post #2 of 5 (permalink) Old 03-10-2013, 02:43 PM
Originally Posted by Raystafarian View Post
Hi All,
Thanks!
Hi Ray - Dunno if this is to late for you or not. You could get the 3/4" radius by drilling the corners first with a 1-1/2" forstner bit. If you have already cut the hole and just want to do the corners, use the forstner bit on some MDF to make a corner template and use a pattern bit (shank mounted bearing). I suppose you could use a tip mounted bearing bit if that's all you have, just mount the template on the bottom of the table.
Making a through hole for the plate, I assume you are going with the Kreg leveling system.
John Schaben
jschaben is offline
post #3 of 5 (permalink) Old 03-10-2013, 05:49 PM
Router Jigs and Templates
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 03-10-2013, 08:17 PM Thread Starter
First Name: Ray
Thanks, John, I'll give that a try. I keep trying to make the template on scrap, so I pretty much have infinite tries at this
post #5 of 5 (permalink) Old 03-12-2013, 05:28 AM Thread Starter
First Name: Ray
Thanks a lot, John. Picked up a forstner bit (drill, not router) and though my geometry is a bit rusty, managed to get the corners pretty close. Good enough for me this time!
rounded corner, inside and out gav General Routing 8 11-09-2011 02:42 AM
corner radius bluebonnetcabins General Routing 33 08-24-2010 01:32 AM
Bit radius or guide radius bill0199 Guide Bushings and Templates 19 07-08-2010 01:33 PM
Beading on an outside radius (face) lay3r3 Table-mounted Routing 32 01-22-2010 01:59 PM
Corner Radius bobj3 Tools and Woodworking 25 09-29-2007 05:51 PM
