My Guide Busching is too long! - Router Forums
post #1 of 9 (permalink) Old 04-18-2013, 02:05 PM Thread Starter
MT Stringer's Avatar
Default My Guide Busching is too long!
I made a jig out of 1/2 inch baltic birch for drilling shelf pin holes. Now I have discovered the 5/8 inch guide bushing I plan to use is too long...about 3/4 inch in length.
Looks like I have two choices:
1) Cut the guide to a shorter length...or
2) use 1/2" mdf to shim up the difference between the jig and the router base
Seems like I always get myself painted into a corner! :-(
What would you do?
The thirty minute clock is ticking!
MT Stringer is offline
post #2 of 9 (permalink) Old 04-18-2013, 02:10 PM
http://www.routerforums.com/jigs-fix...ss-guides.html
post #3 of 9 (permalink) Old 04-18-2013, 02:24 PM Thread Starter
Thanks Bob. I was just going to use a hack saw and a vise. I have the Bosch guide bushings and they appear to be metal.
post #4 of 9 (permalink) Old 04-18-2013, 03:12 PM Thread Starter
Holes are drilled. My jig could use a little tweaking but for now, it is OK.
Thanks again BOB. I will look at your jig a little closer for future use.
post #5 of 9 (permalink) Old 04-18-2013, 04:39 PM
ggom20's Avatar
Country: France
First Name: Gerard
What would you do?
Hello!
Fast: Use solution n2
Or if you need more plunge capacity: solution n1
Sort of a jig made of 1/2 " plywood plate with a hole in it ,
attach the guide bush and then a metal hand saw+ sanding should get it straight
and clean.
No need for band saw or metal lathe.
Regards.
Gerard.
ggom20 is offline
post #6 of 9 (permalink) Old 04-18-2013, 05:26 PM Thread Starter
Originally Posted by ggom20 View Post
Hello!
and clean.
Regards.
Gerard.
Thanks. That's a good idea. I might do just that.
post #7 of 9 (permalink) Old 04-18-2013, 09:41 PM
Hi Mike, I like the short barrel variety for just that reason. I seldom use template material thicker than 1/4" and Eagle America and Woodcraft both sell the Porter Cable style that short. The ones I've needed to cut down, I did on the bandsaw using a piece of 3/16" hardboard, with a hole for the barrel to stick through, as a spacing shim to get the barrel length.
John Schaben
jschaben is offline
post #8 of 9 (permalink) Old 04-18-2013, 11:30 PM
Exclamation
That is what Pat warner does. If it's good enough for Pat, it will do me.....
Use a piece of 1/4" acrylic as a spacer to avoid damage to the bushing.
Sydney, Australia
jw2170 is offline
post #9 of 9 (permalink) Old 04-18-2013, 11:45 PM Thread Starter
More than one way to skin a cat, huh? Thanks for the suggestions.
I got the holes drilled, and by some miraculous stroke of luck, they are all in the right spot.
Routing ends of long, narrow boards. Grouchy Jigs and Fixtures 12 12-21-2012 06:09 AM
Guide bushing or guide bearing??? argentum Jigs and Fixtures 8 10-08-2012 05:53 AM
ABSOLUTE ROUTING BEGINNER: Need to make 36" long 3/4" wide 3/8" inch deep insert tkleff General Routing 9 02-20-2012 06:10 AM
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
Template Guide depth ttait General Routing 3 10-03-2004 05:16 PM
